Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-04-2004, 11:58 AM   #1
Bryanhu
Profile:
Univolt boiling battery! On for 12 hours!!!
I checked my battery compartment this morning and heard my battery cooking! Ahhhhhhhhh. Apparantly the univolt is over charging. What causes this?
Do I trash and get a replacement, or try to fix it? Battery reads 13.5 volts- think it's still good? Ah one more thing, oh well. Your thoughts and ideas are always very much appreciated. Thanks. Bryan/Dallas
Bryanhu is offline   Reply With Quote
Old 04-04-2004, 12:12 PM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
bryan
was it boiling or just out gassing as all batteries do when they charge?
some bubbling is normal and will subside after the battery becomes fully charged.
john
you call them ferrets, i call them weasels.
Old 04-04-2004, 12:16 PM   #3
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Bryan,
Pull the battery and see if it still has water in it. If it does, you should be fine, I would bet it will need some. I would also check the cells with a hydrometer to see what the status of all the cells are. Sometimes a boiled battery is due to a bad cell causing the Univolt to overcharge.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 04-04-2004, 12:24 PM   #4
john hd
john hd's Avatar
madison , Wisconsin
Images: 40
Originally Posted by thenewkid64
Bryan,
DUH!
forgot about the possibility of a dead cell!
good point brett!
john
Old 04-04-2004, 12:25 PM   #5
Bryanhu
Profile:
The battery was very hot. I added alot of water so I do not know if it was empty or not. The battery is new/ never really used.
Old 04-05-2004, 09:35 AM   #6
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
Cool
been there done that. after three sets of battery's i trash
the univolt and bought a intella power 9160 with charge wizard. CAN LEAVE IT PLUGGED ALL THE TIME AS THE CHARGE WIZARD CONTROLS THE CHARGER CAN BE SET MANUALLY FOR THE DESIRED CHARGE RATE. the univolt does its thing and cooks battery's. cant set any thing.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 04-05-2004, 10:58 PM   #7
jjonesnc
jjonesnc's Avatar
Profile:  Cary , North Carolina
Images: 8
My Father the Electronics GURU helped me fix my Univolt. It was putting out 30 volts and boiling batteries dry in a few days, im lucky they didnt explode.
Replaced Capacitors with 2-20UF@480 VAC wired in series which gives 10UF@960VAC. Works great now!
jjonesnc is offline   Reply With Quote
Old 04-09-2004, 09:20 PM   #8
j&jsoldsilver
j&jsoldsilver's Avatar
Profile:
Talking Battery boiling
I had the exact same problem. I smelled the rotten egg odor inside & knew something was wrong. The univolt had boiled approx. one-half gallon of water out of a relatively new battery in 24 hours. Thanks for info. on a fix. I may have to wait a little while to get to it though. I the meantime I will disconnect the negative cable when connected to AC power. When trailering I will reconnect the battery cable to activate the emergency disconnect switch if needed.
j&jsoldsilver is offline   Reply With Quote
Old 04-10-2004, 06:03 AM   #9
Bryanhu
Profile:
Installed an new 9100 with the "Charge Wizard". I am now happy! man, the voltage, is EXACTLY the way the manual says and I think I have now nothing to worry about. Also got AC installed yesterday! Ready to go!
Bryan
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Univolt reminder ** Battery Check! Sav'h Steve Batteries, Univolts, Converters & Inverters 21 10-07-2003 03:18 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 09:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 08:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
test
