Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-05-2004, 06:52 PM   #15
jjonesnc
jjonesnc's Avatar
Profile:  Cary , North Carolina
Images: 8
Originally Posted by tcwilliams
Your Univolt is overcharging if you have to make a concerned effort to keep water in the battery.
A battery will bubble (i.e. lose water) if left charging at 13.5 volts AFTER it has reached fully charged.
Sorry,
Tom
An automobile puts out 14.2 and they dont "kill" balleries off of 14.2 and they need the water topped off periodically.
Batterys go bad when the water gets low.
Check the water once a month and it will be fine .
I have been in Automotive service for 12 years, batteries go bad when the water level in not maintained.
jjonesnc is offline   Reply With Quote
Old 04-05-2004, 07:06 PM   #16
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
You are right. But an automobile does not put out that voltage 24-7. A battery at rest puts out 12.5 or so volts. Any voltage higher than that will charge it. Charging a battery will make it bubble. Bubbling means losing water.
Regardless, if water has to be constantly added to a battery, the battery is being overcharged. In my laziness, I do not care to add water to a battery on a constant basis. Your points are valid. But, please do not attempt to tell people that a correctly functioning Univolt means seldom having to add water to the battery. Univolts will overcharge.
Tom
Old 04-05-2004, 08:11 PM   #17
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Ok, but if I have a "sealed" Interstate RV battery, how does one add water? I can't see anything that allows me too.
Marc
Old 04-05-2004, 10:43 PM   #18
jjonesnc
jjonesnc's Avatar
Images: 8
Tom
I never used the words "constantly" or "seldom"
A properly functioning univolt will not ruin a battery IF the battery water level is checked once a month and added as nessecary (I seldom have to add water to mine but thats just mine im not speaking for others.)
Anytime a car engine is running it will produce 14.2 volts to the battery.
Old 04-05-2004, 10:45 PM   #19
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Marc
I have maintenance free sealed Delco Voyager batteries and rarely charge with the Magnetek charger that was put in my Excella by the PO. I keep the batteries charged with a 5 watt PulseTech Solargizer solar charger and a BatteryMinder multi-step charger which are both plugged in 24 hrs. a day at the house. The trailer is at the hunting camp now for 4 weeks where it will be charged daily by the 5 watt solar panel. Last weekend I plugged in an additional 20 watt solar panel while there for 2 days and when I left Sunday I pulled it off the roof and put it inside the trailer. I've had these batteries for almost 3 years now with no problem. You have to be careful you do not overcharge sealed batteries so make sure your charger is in good shape.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Univolt boiling battery! On for 12 hours!!! Bryanhu Electrical - Systems, Generators, Batteries & Solar 8 04-10-2004 06:03 AM
Univolt reminder ** Battery Check! Sav'h Steve Batteries, Univolts, Converters & Inverters 21 10-07-2003 03:18 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 09:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 08:59 PM
test
