Old 07-11-2015, 06:43 PM   #1
2007 25' Safari FB SE
Bemus Point , New York
Unable to connect battery power
2007 Safari 25 FB works fine on external power or on truck power. No power from trailer batteries which are fully charged. Battery disconnect fuse (5 amp) on panel under bed is good. Any ideas?
dsanctuary is offline   Reply With Quote
Old 07-11-2015, 07:57 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
You could have a bad disconnect solenoid. You can wire around the solenoid if necessary. Find the heavy red cable (battery direct) at the bottom of the positive bus bar and add a jumper cable (6AWG minimum) and connect it to the right side (the other heavy red cable that leads to your power center) of the solenoid, leaving cable #2 in it's place. This will power your entire trailer.
Of course, disconnect your batteries BEFORE attempting this work-around!
***It would also be prudent to check the fuses on the solenoid and using a DC volt meter, check the solenoid to see if it indeed works or doesn't. If you don't follow any of this or unfamiliar with the proper use of a meter, find an RV tech who does and have them do it.
Old 07-11-2015, 09:12 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I don't know how your trailer is wired, but on my 2001 trailer the disconnect switch disconnects both the batteries and the converter from the 12V fuse panel. As a part of the 12V distribution system there is a "resettable fuse" or circuit breaker that is thermally activated in the line to the batteries. If that was bad, everything else would work, but not the trailer batteries. You said the battery disconnect fuse was good, but said it was a 5 amp. Did you mean 50? If so, then ignore the above.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Cant figure out how to connect my AS to power cantdrv55 Generators & Solar Power 15 05-27-2015 04:23 PM
Unable to ground the battery hamiltonmj Electrical - Systems, Generators, Batteries & Solar 5 03-19-2015 08:30 PM
OK to connect a battery charger when the internal one fails? DJW Batteries, Univolts, Converters & Inverters 3 01-06-2014 11:56 PM
Unable to get power from my truck battery when connected to the trailier! Ribbler Electrical - Systems, Generators, Batteries & Solar 8 10-08-2012 07:45 PM
New airstreamer..How I connect the power cord to test the appliances and AC yam Member Introductions 5 08-21-2006 08:06 PM
