Old 03-31-2012, 12:56 PM   #15
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Originally Posted by CrawfordGene View Post
Some clocks have a battery that keeps the clock going for a while, but others don't. Sometimes they tell you if the power went out.
Hmmm. Maybe I ought to get a plug-in clock from a charity shop just for stuff like this for a bit until I'm relatively sure everything's okay? The microwave and the CD player seem to be okay, and those are the only things that have clocks in them...
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline   Reply With Quote
Old 03-31-2012, 01:07 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It is the clock that stops or has the wrong time that tells you the power has been interrupted. A split second outage may not tell you anything. A clock that is normal tells nothing except the time. It is just something that may give you a clue.
Gene
Old 03-31-2012, 01:13 PM   #17
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Well, I figured a digital one might flash at least. I really hope it's not the converter and that it's just a momentary power failure...
Old 03-31-2012, 02:47 PM   #18
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
It could have been that camcorder restarting the tape reel??
Dave
Old 03-31-2012, 03:11 PM   #19
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
ooo, er, missus!!!
Old 03-31-2012, 07:27 PM   #20
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Our power in the USA runs at the 60 cycles rate,, Any imbalance will make battery chargers or inverters buzz or hum more than normal as its trying to digest a square wave an not a normal sine wave.. Just my guess.
Sodbust
Sodbust is offline   Reply With Quote
I was told 'Not to Join'??? Travel Bird WBCCI Forum 159 05-09-2015 05:46 AM
Need help, replace rivets or try to seal? timzog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-25-2012 11:40 AM
Please help! Rental to tow with DE to MA etobolski On The Road... 25 04-03-2012 06:21 PM
Safe to Travel Dfh54418 1959-69 Tradewind 2 03-31-2012 07:08 AM
