Old 03-11-2017, 10:35 AM   #1
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Umbilical cord: Straight or coil?
I've got an older coach with the removable umbilical cord. I just replaced the vehicle end connector, and I'm about to replace the coach end connector. I'm wondering if I shouldn't just go ahead and replace the umbilical cable as well.
Has anybody tried the coiled type? Opinions?
Thanks!
Don
Old 03-11-2017, 10:39 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I like the idea of the coiled cord. I have to tie mine up to keep from dragging the ground.
MICHAEL
Old 03-11-2017, 10:46 AM   #3
1976 31' Sovereign
Oswego , Illinois
I don't no if my 76 AS cord is removable, if so would use coiled. I loop mine around rod for propane tank hold down to keep from dragging.
Old 03-11-2017, 12:32 PM   #4
1976 31' Sovereign
Oswego , Illinois
Angry
Loss of memory my cord does unplug from out side of front.
Old 03-11-2017, 02:50 PM   #5
drboyd's Avatar
1978 25' Tradewind
First you forget names. Then you forget faces. Then you forget to pull your zipper up.
Finally, you forget to pull your zipper down.
--George Burns
Old 03-11-2017, 02:57 PM   #6
AWCHIEF's Avatar
Images: 33
Robert Cross I tried to respond to your PM. Seems blocked. Thanks for the idea. I think I have a couple of those somewhere.
MICHAEL
Old 03-11-2017, 03:36 PM   #7
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Thanks!
Don
Hey Don. On our (old, used) '73, I had to purchase an umbilical because it didn't come with one. I picked one up at NAPA for about $30. The trailer end had to be wired in according to the wiring scheme of the Airstream. It is the coiled type. I was initially concerned that it would pull loose because of the coiled, "spring-like" feel when connected. Never been a problem in several thousand miles of towing.
There are several different types available. I think it'll work for you just fine.
www.nesa.org
Air No. 6427
Old 03-11-2017, 03:57 PM   #8
1976 31' Sovereign
Oswego , Illinois
Smile
--George Burns
So far 2 out of 3. #3 not yet and not good.
Old 03-12-2017, 05:48 PM   #9
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
I made the pictured hanger out of a large electrical conduit clamp and an eye bolt. Clamps to tongue jack post. Trimmed an opening in the eye bolt to allow the cable to pass through. Purchased connector cover online.
Greg
greghoro is offline   Reply With Quote
Old 03-12-2017, 06:16 PM   #10
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
--George Burns
That's funny. Thanks George.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Axles: Dexter, Leaf Springs, Coil Springs, Straight Axles Ray Eklund Axles 22 09-10-2016 06:02 PM
Umbilical cord/battery draw davidz71 Electrical - Systems, Generators, Batteries & Solar 5 06-16-2008 10:33 PM
Install new umbilical cord beginner5 Electrical - Systems, Generators, Batteries & Solar 7 07-09-2007 09:02 PM
Umbilical cord mickleton Electrical - Systems, Generators, Batteries & Solar 4 07-07-2007 10:25 AM
old stlye umbilical cord mrbeanpa Lights - Interior & Exterior 4 03-15-2006 11:37 AM
