Old 09-27-2019, 08:48 AM   #1
2018 25' Flying Cloud
Mission , Texas
Umbilical cord separation
Does anyone have this issue and a possible solustion? So far all is well with the connection, but if this continues to pull apart and water gets into the plug I could have a problem.
ghamr is offline   Reply With Quote
Old 09-27-2019, 09:16 AM   #2
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Hereís a little gadget to keep it dry - $7.00 at Amazon
John & Vicki
WBCCI #4291
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 09-27-2019, 09:17 AM   #3
2007 22' International CCD
Only real permanent solution is to replace the plug or the whole umbilical cable. Itís basically coming apart.
A new one is not that hard to install.
Old 09-27-2019, 09:24 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Most auto parts stores sell liquid electrical tape which might be all you need. Swab two or more coats on a day or so apart.
Tom
Old 09-27-2019, 10:12 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ours did that within 2 weeks of install... 3 years ago... still fine.. I tuck it under the propane tanks when we are parked.. no issues.. just keep the connections clean and dampen with dielectric on TV too.
You can 'tape' up.. but I found this stuff is miraculous for fixing power cords at stress points.. may try on this later...hmmm
https://sugru.com/
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-27-2019, 12:16 PM   #6
1981 31' Excella II
New Market , Alabama
Loosen the clamp and shove it back in the shell then tighten the clamp. Also the ends of the wires could be too long. Shorten and put the shell back on. It is a common problem. Mine needs the same treatment.
Perry
Old 09-27-2019, 02:09 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
From the picture, it looks like you have a moulded plug on the cord rather than a clamp on. There's not much you can do to pull it apart and fix it. Basic choices:
1) Ignore it until it fails. Since it may fail one wire at a time, this means checking your lights, brakes, charge wire and signals on a regular basis. (we all do that all the time anyway .... right? .... )
2) Replace the 7 pin with a clamp on 7 pin
3) Replace the whole cord with a new one.
Lots of fun !!!
Umbilical Cord Replacement watt1968 Electrical - Systems, Generators, Batteries & Solar 5 06-13-2009 06:39 AM
Umbilical cord/battery draw davidz71 Electrical - Systems, Generators, Batteries & Solar 5 06-16-2008 10:33 PM
Install new umbilical cord beginner5 Electrical - Systems, Generators, Batteries & Solar 7 07-09-2007 09:02 PM
Umbilical cord mickleton Electrical - Systems, Generators, Batteries & Solar 4 07-07-2007 10:25 AM
old stlye umbilical cord mrbeanpa Lights - Interior & Exterior 4 03-15-2006 11:37 AM
