Old 06-12-2009, 08:26 PM   #1
watt1968's Avatar
1968 30' Sovereign
Pelzer , South Carolina
Umbilical Cord Replacement
My umbilical cord was cut (torn) into and repaired when I bought the camper. I want to replace the cord. I went to a local ma and pa hardware store that carries some camping supplies. The cords they had were too short and way over priced. Can I get the 7 wire electrical cord at Lowe's or Home Depot? Is the color code standard and how about the gage? I'm sure someone out there can give me some good advice. Thanks!
watt1968 is offline   Reply With Quote
Old 06-12-2009, 08:46 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The 7 way wiring now is standard but was not in 68. This means unless a PO has rewired the 7 way connection to match the new standard you will get strange results especially with the signal lights. This correction can also be made in the TV plug or the umbilical itself.
Old 06-12-2009, 08:51 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Umbilical cord
If your trailer still has the original connector (7 round pin female). You can just cut the cord and use the old 7 wires to note the location (color) in the plug. Then remove the access panel from your belly skin and note what color wire goes where. Clean the connectors in the plug and convert the recepticle on your tow vehicle to a 7 pin male. (The round connectors don't corode and lose contact as easily as the flat blade connectors do). Hook it all back up after lubing the connector pins with dielectric grease and you should be good to go. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-12-2009, 09:05 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
This graphic should help assist you in getting the right wires in the right location. I have planned to put a female receptacle on the trailer as well so i can remove the umbilical cord altogether. In the Arizona desert, the sun really does a number on an electrical cord after about two years.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-12-2009, 09:08 PM   #5
richinny's Avatar
2011 34' Classic
Northern had 7 pin flat blade umbilical cords for a great price last winter.
Portable Generators, Pressure Washers, Trailers, Hand + Power Tools | Northern Tool + Equipment
Ricky
Old 06-13-2009, 07:39 AM   #6
watt1968's Avatar
1968 30' Sovereign
Thanks everyone for your knowledge an ideas. I will follow up with a trip to Northern Hydraulics to look at their cords, round pin and flat connectors, etc. Again Thanks!
Umbilical cord/battery draw davidz71 Electrical - Systems, Generators, Batteries & Solar 5 06-16-2008 11:33 PM
Install new umbilical cord beginner5 Electrical - Systems, Generators, Batteries & Solar 7 07-09-2007 10:02 PM
Umbilical cord mickleton Electrical - Systems, Generators, Batteries & Solar 4 07-07-2007 11:25 AM
old stlye umbilical cord mrbeanpa Lights - Interior & Exterior 4 03-15-2006 12:37 PM
External Power Cord Replacement jstaad Electrical - Systems, Generators, Batteries & Solar 3 01-23-2003 07:16 AM
