Old 10-25-2008, 01:28 PM   #1
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
umbilical and kill switch
why am I registering 12.6v at the a/s umbilical when the kill switch is 'off'?
boondockdad is offline   Reply With Quote
Old 10-25-2008, 02:12 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't know anything about new Airstreams but in older Airstreams the umbilical wiring is independant of the rest of the trailer and runs off the TV except for the breakaway switch connection.
Old 10-25-2008, 02:55 PM   #3
Dearborn , Michigan
Images: 21
my trimetric reads -.05 everything off. -.09 everything off, my TV plugged in and running... a voltmeter shows 12.6 at the 7-way on the TV...
Old 10-25-2008, 03:10 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Is there a problem?
Joe,
If there is a battery installed in your Airstream, there will be battery voltage available at the "charge" wire on the umbilical for you to read.
Is there a particular issue that prompted you to measure voltage on each of the seven wires?
Tom
Old 10-25-2008, 03:12 PM   #5
TomW's Avatar
1967 26' Overlander
Originally Posted by finalcutjoe View Post
...TV plugged in and running... a voltmeter shows 12.6 at the 7-way on the TV...
The TV is trying to charge your Airstream's battery.
Tom
Old 10-25-2008, 03:13 PM   #6
Dearborn , Michigan
Images: 21
yeah... the trimetric is reading -.05 everything off and -.09 with the suburban plugged in and running...
Old 10-25-2008, 03:24 PM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Joe,
What's the reading at the TV battery, was it running?, 12.6 seems a little low.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-25-2008, 03:32 PM   #8
SteveH's Avatar
Common Sense , Texas
I think the kill switch is between the battery and the trailer system (load), but the battery stays connected to the converter and the umbilical.
Regards,
Steve
Old 10-25-2008, 03:49 PM   #9
Dearborn , Michigan
Images: 21
yup... 12.6 while the burb was running... I figured if I plugged in the TV, running, I would show charge on the Trimetric... instead I show a draw of an extra ~40mA... not only is there supposed to be an isolator.. but there should be charge, right?
Old 10-25-2008, 04:05 PM   #10
All I know for sure Joe is when I'm plugged in and running, the voltage in the trailer and TV are the same, 13.9v. What reading do you get in the Burb with trlr disconnected?
PFC
RLC
Rant! Over kill Ultradog Off Topic Forum 37 04-29-2007 10:04 AM
Kill File? guy99 Forum Admin, News and Member Account Info 14 04-11-2007 05:54 PM
Something new to kill your time. cosmotini Our Community 1 08-04-2006 05:00 PM
master kill switch Deborah V Our Community 6 09-06-2004 07:43 AM
Kill switch for electric jack ? remark83 Jacks, Stabilizers, Lifting and Leveling 9 06-24-2003 10:14 PM
