Old 05-11-2015, 01:27 PM   #1
Airborne6's Avatar
2015 23' International
Lakeview , Arkansas
Two LEDS remain on while on shore power?
Just curious if the tail lights on a 2015 23D normally have two LED remain eliminated while plugged in to 15 amp shore power? Thought maybe it was just a reflection at first but is not. Night light perhaps??
Some days your the bug.
Some days your the windshield.
WBCCI # 1959
Black 2015 Toyota Tundra TRD Pro CrewMax
2015 23D International Signature (Salsa)
Stella our Bull Pointer mix
Airborne6 is offline   Reply With Quote
Old 05-11-2015, 01:35 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
They are 2 completely different electrical systems and have nothing in common.
The shore power is 120 volts ac and the tail lights are 12 dc.
Considering the age of the trailer I would ask the dealer or call Jackson Center.
Are you saying if you unplug the shore power those lights will go out?
2004 Excursion 4x4
Old 05-11-2015, 02:13 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Is the trailer hooked up to the tow vehicle when this happens?
Also, I note that it's pretty wet in the photo... is the end of the umbilical dry and clean? It doesn't take much juice to light an LED, so (at a stretch) could be a tiny amount of current from the 12v hot on the umbilical to the input for this light (signal or running lights) and those 2 LEDs are more sensitive than the rest.
David
Old 05-11-2015, 02:24 PM   #4
bwpaint's Avatar
2015 25' FB International
my , house
This happened on my trailer also. I had just washed it, and I noticed the tail lights were glowing slightly. Turned out my umbilical had gotten very wet not being plugged into TV. Unplugged trailer from shore power and dried the cord. I plugged back in and all was fine.
bwpaint is offline   Reply With Quote
Old 05-11-2015, 02:46 PM   #5
HowieE's Avatar
Images: 12
There is no appearance of shore power in the umbilical cord. That cord is only used with the 12 dc system.
Now if the cord was wet and if there is a "whisker of wire" free inside the connector on the umbilical cord you might have a connection between the battery wire and the tail light wire.
The storage switch isolates the trailer lighting from the batteries. Not sure if it isolates the umbilical cord also. I would assume it does not.
I would open the connector and inspect for a floating whisker of wire between Black and Brown wires. They are the battery and right hand directional terminals.
If it is not the right hand light that is on we have a different ball game.
2004 Excursion 4x4
Old 05-11-2015, 02:47 PM   #6
bwpaint's Avatar
my , house
May have had my battery switch in store position, no 12v available, or I may have only noticed after I plugged the trailer into shore power. Either way air hose and time to the umbilical fixed it.
Old 05-12-2015, 10:18 AM   #7
Airborne6's Avatar
Lakeview , Arkansas
Thanks all for your responses. It has been raining here on Lake Superior for a few days. I had added a dust cap to the umbilical cord witch is great for keeping dirt from the connections but if hanging the wrong way will collect water like a tiny kiddie pool. . Pulled the cover and dried it out. No more lighted LEDs in tail light. Thanks again. Great forum.
WBCCI # 1959
Old 05-12-2015, 10:37 AM   #8
1974 Argosy 20
Kooskia , Idaho
Those dust and dirt covers do more harm than good. As noted they can easily become a water collector and cause issues such as the one Airborn6 found. I always position my cord so the end hangs down and in free air so the water cannot get trapped inside.
A leaky cover or a backward sloping outlet on the tow vehicle can also cause issues. I had one once which had live + 12 volts all the time for charging the trailer batteries. A little leak and road grime and the power leaked from the +12 volt pin to ground and/or the other pins and the result was a green corrosion mess like you can find on a car battery terminal. It did so much damage to the outlet over the winter that I had to replace it entirely.
Old 05-12-2015, 01:15 PM   #9
2014 27' FB International
Clearwater , Florida
I had this problem. Found the umbilical had been pinched. Shorting the taillight wire to the 12v wire.
ChuckFeldt is offline   Reply With Quote
Old 05-12-2015, 02:23 PM   #10
HowieE's Avatar
Images: 12
They will all eventually find that is the problem. Water does not conduct 12 dc power to the extent it will light an LED. If they open the connector they will find a whisker almost touching between the 12 volt terminal and the right hand directional terminal. The connector on the umbilical cord is an extremely cheap and poorly designed system. If extreme care is paid while connecting the wires all sorts of problems can occur.
Such a design would never pass any cord requirement.
2004 Excursion 4x4
Old 05-12-2015, 07:25 PM   #11
Airborne6's Avatar
Lakeview , Arkansas
HowieE. My particular problem eluminated both left and right tail light. It only effected two LEDs in each tail light. As soon as I pulled the dust cover and blew the water from the contacts the eluminated LEDs went out. All seems to be good now.
WBCCI # 1959
Old 05-12-2015, 08:07 PM   #12
bwpaint's Avatar
my , house
Sorry to contradict your theory, but my problem was water in the umbilical. No wire whiskers here.
Old 05-12-2015, 09:33 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I "drape" my umbilical under the LP tank cover. Hard to get water or dirt up there. If your cord is "molded" it should be watertight at the wire end and the "cap" could keep it clean and dry under the LP tanks. I won't use the cap for the very reason you experienced.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-13-2015, 10:45 AM   #14
HowieE's Avatar
Images: 12
Did you open up the umbilical cord and check? Unless you opened the connector there is no way to get air to the area in question
Airborne6
If both lights were on it is in the parking light circuit. Open up the connector and look for a bridge between the Black and Green wire terminals. I don't think water allow will carry enough current to supply the 9 volts necessary to light an LED.
To ensure that road vibration and general stress on the cord don't cause a short between terminals I solder each connection and wrap each with electrical tape.
2004 Excursion 4x4
hardwired stuff died while on shore power rec Batteries, Univolts, Converters & Inverters 3 08-16-2014 11:59 AM
Can I disconnect battery post while on shore power? pinetar Batteries, Univolts, Converters & Inverters 3 06-25-2014 08:41 PM
Air Conditioner tripping breaker in my house while on shore power Wgbarrbevco General Repair Forum 10 08-16-2012 06:07 PM
Charging Battery While Plugged in to Shore Power Kevin245 Batteries, Univolts, Converters & Inverters 2 12-29-2007 01:10 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
