Old 11-12-2015, 12:12 PM   #1
LAFAYETTE , Colorado
Two 6 volt batteries replacing one 12 volt
Hi,
Obviously I am non electrical minded. Changing out my 12 volt to two 6 volt batteries on my 2006 Bambi 16ft. Series is my guess ie positive from trailer to positive post of battery one and negative to frame from negative post of battery two, then connect the positive and negative between the two batteries. Am I on the right track?
TY PECK is offline   Reply With Quote
Old 11-12-2015, 12:22 PM   #2
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
See my thread here: http://www.airforums.com/forums/f449...ld-143063.html
I posted a bit further down the wiring diagrams of various 6V combos.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-12-2015, 12:22 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by TY PECK View Post
Hi,
Close. The negative cable from the battery will go to your negative bus bar inside the trailer. From there, it should have an existing negative connection to the frame.
12 volt
Two batteries Use only one? jbailey01 Batteries, Univolts, Converters & Inverters 4 05-31-2013 12:57 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Are there two batteries,or just one ? PINKBIKE Batteries, Univolts, Converters & Inverters 8 11-02-2010 08:24 PM
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-22-2010 11:50 PM
Two 6 volt batteries on International AS nayl 2002 - 2005 International 9 03-24-2005 08:23 PM
