Old 10-12-2016, 10:43 AM   #1
Breezinalong's Avatar
2010 25' FB International
2016 26' Flying Cloud
Albuquerque , New Mexico
TV Question
Can a TV operate without shore power or generator? On our 2010 AS it didn't, but the prior owner had screwed around with the electric system a whole bunch. We've sold that one and are taking delivery on a 2016 shortly and I'm hoping we can at least peek at the news now and again if we are boondocking.
As to battery drain, we are installing 240W up top of solar.
Breezinalong is offline   Reply With Quote
Old 10-12-2016, 10:51 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There are 12v DC TVs. Also you can use a 12v DC to 110v ac inverters but you loose a little in amp hours. Some TVs come with a transformer that converts 110 to 12v and you can bypass the transformer and wire them direct.
Old 10-12-2016, 11:03 AM   #3
So I'm guessing, then, this is not an "off the lot" thing, but something we'll have to do aftermarket?
Old 10-12-2016, 11:06 AM   #4
NCMEDIC's Avatar
2010 27' FB Classic
LINCOLNTON , North Carolina
Some of the newer models have two different receptacles behind the tv. One for the 110 power and one that runs off of the inverter.
NCMEDIC is offline   Reply With Quote
Old 10-12-2016, 11:10 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If it comes with an inverter, you do not need to do anything. Just pug in your 110VAC TV. If you are parked in a 110VAC campground the same thing. If there is no inverter, you can add one for just a small flat screen for under $50.
Old 10-12-2016, 01:32 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Google 12v TVs. Check truck stops. You can get a small 12v DC to 110v AC inverter at an auto parts store. For a small flat screen this is a no brainer. A bigger TV might need some engineering.
So you have 2 options:
1. A 12v DC TV running off your 12v system
2. A 110 v AC run through a built in or add on inverter with a 12c DC power supply.
You can also get a TV with a built in DVD player.
Old 10-12-2016, 02:03 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have the inverter option but you could also power a small portable inverter off the batteries.
Doug and Cheryl
