Old 08-22-2011, 04:55 PM   #1
Turtle's Avatar
2004 16' International CCD
Arcata , California
TV battery jumper to tongue jack.
I'm trying to make a jumper from the TV 7 pin to the tongue jack so I don't have to lug my 2 heavy 6 volt batteries to the storage lot just to bring my trailer home for maintenance. I bought a female 7 pen and hooked up wires to the aux and ground and spring clamps on the other end. No go. I put a volt meter on the TV 7 pen and get nothing out of any pen. I grounded to the TV and then went around the horn with the + lead. Nothing. With the trailer plugged in to the TV everything works fine. What am I missing? Jamie
Turtle is offline   Reply With Quote
Old 08-22-2011, 05:20 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
the tongue jack normally runs off the charge line pin not the auxilairy pin. Sorry I don't remember the pin # or color off the top of my head
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 08-22-2011, 06:37 PM   #3
Turtle's Avatar
Arcata , California
My tongue jack runs straight off of the battery. I just want to use the truck battery during storage retrieval (I keep the batteries at home so I can keep them charged). I could use a long wire from the truck battery to the jack but was hoping to use less wire. Jamie
Old 08-22-2011, 06:51 PM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Looking at the back of the trailer side of a 7 way female plug, (meaning the screw terminals) 12 volt positive is the at 1 o'clock, and ground is at seven.
Follow the link, and scroll down the page to the 7 way diagram.
http://www.etrailer.com/faq-wiring.aspx
If you know which wires are positive and ground on the jack, you are good to go.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-22-2011, 07:36 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
7-way....
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 08-23-2011, 07:57 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Just plug in the cord from your truck and you should be fine. Remember that if you tow without a battery in the trailer, the breakaway feature will not work.
Richard
Old 08-23-2011, 07:33 PM   #7
Turtle's Avatar
Arcata , California
Good call on the breakaway. My rationalization is that I'm only going less than a mile and never over 25 MPH from storage to home. I don't even put on the extension mirrors or load leveling bars. As for just plugging in the cord, that doesn't work. The tongue jack is hooked up to the battery only. So there isn't a hot lead from the truck battery on the 7 pen? And if so, why won't it show on my volt meter? Jamie
Old 08-23-2011, 08:06 PM   #8
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Just be absolutely sure that both of the loose positive battery cable ends are securely isolated from ground before plugging in the truck. Other than that, this seems by far the simplest solution.
Ken
Old 08-23-2011, 08:26 PM   #9
Splitrock's Avatar
Sioux Falls , South Dakota
Interesting thread. The jack on my trailer is connected directly to the hot battery charge line from the tow vehicle. The charge line is connected to the trailer battery. If my trailer battery is removed, the jack on my trailer is connected directly to the hot battery charge line from the tow vehicle.
Sidebar: I call electric jacks "stranded jacks". I'm replacing mine with a front handle sidewinder jack.
Old 08-23-2011, 09:10 PM   #10
2002 25' Safari
Dewey , Arizona
Images: 62
The "hot" line as you call it is the charge line to the trailer battery. In most TVs the key must be on to energize that line. In some TVs a fuse has to be added to the truck as well.
Richard
Old 08-24-2011, 05:26 AM   #11
Ken,
Richard brings up a good point. Do you know for sure that the "charge" line was ever live when unhooked?
Not sure how it's wired on your Ford, ours is fused and hot all the time.
Your FoMoCo manual should tell you.
PFC
"Tahawus"
RLC
John Prine
Old 08-26-2011, 10:02 AM   #12
Turtle's Avatar
Arcata , California
Bingo! for Richard in post #10. The answer to my whole problem was to have the truck ignition switch in the "on" position. Then everything works as I had hoped. I tried the acc. position initially but that didn't work. The longer I live, the more I learn. I think I'll need to live to 150 to lose my Knucklehead status. Thanks to all for your input. Jamie
Old 08-26-2011, 10:11 AM   #13
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I was going to suggest using a bottle jack on a bunch of scrap wood to jack up the tongue if nothing else worked. Now I won't.
Gene
Old 08-26-2011, 10:18 AM   #14
Turtle's Avatar
Arcata , California
Gene, Not a bad idea as a backup for when things go wrong, electrically speaking. I have had the up/down switch corrode and not work. It's not that easy to crank up with the emergency crank. Jamie
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Ultra Fab Odyssey 3000 Tongue Jack indy Jacks, Stabilizers, Lifting and Leveling 0 04-15-2011 09:49 AM
Need Tongue Jack - Suggestions? kj78133 Jacks, Stabilizers, Lifting and Leveling 16 02-23-2011 05:55 PM
