Old 11-25-2018, 02:43 PM   #1
2019 22' Sport
Quartzsite , Arizona
Turning Off Solar
Howdy,
Is just flipping the breakers the easiest/best way to disable solar panels?
I'm replacing my converter today and have batteries and shore power disconnected but wonder if I have to disable solar to be safe? Or is charge minimal enough to not harm anything?
Bright sunny Arizona day so solar should be pumping full charge!
Rounder44
aka
Warren
Rounder44 is offline   Reply With Quote
Old 11-25-2018, 04:10 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Hi Warren,
That depends on whose panels you have. If they are Airstream stock panels, I don't believe that you have any switches or breakers in their system. If you have a different system, I would definitely move the breaker/switch to the OFF position before you start your project.
Originally Posted by Rounder44 View Post
Howdy,
Rounder44
aka
Warren
Old 11-25-2018, 06:22 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You disable most stock AS solar installs by pulling the fuse in the 10 ga wire coming down from the roof. In some cases it's behind an AC vent.
Old 11-25-2018, 07:42 PM   #4
2018 27' Globetrotter
Mooresville , North Carolina
Could you just put blankets over the solar panels so the sun couldn't activate the panels?
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 11-25-2018, 07:46 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i installed a cutoff switch , just like the DC cut off.
that way i can work on the electronics and MPPT controller without any solar power coming in
i also shut it off for the winter when the AS is covered.
waninae39 is offline   Reply With Quote
Old 11-26-2018, 09:51 AM   #6
I am planning on replacing my converter as well, similar to Rounder44, except mine will be on a 2018 27 Globetrotter. A person I know did the same thing on his Globetrotter. He isolated the battery from the TT similar to Rounder44 and was unaware of the solar still working when the battery was in the Store position and batteries disconnected. He did not have any issues but was careful to make sure no bare wires touched anything they should not touch.
I would like to disconnect the solar as well, if possible, as an extra safety step. If anyone is aware of where this is done, I would appreciate it. i.e. a) if the fuse is behind an AC vent, then which vent and b) if a cut off switch was installed then where did you install the cut off switch and what kind of switch was used.
I will admit that electricity is not one of my strongest points but I can follow directions if they are spelled out for me. In the case of my GT, I have removed the breaker / fuse panel to see the location of converter and wiring. It looks to me the converter has an basic electric plug into the back of the breaker panel and that there is a Positive / negative and ground wire going into the converter from the fuse panel. It appears to me the that if I can not locate the fuse for the solar I need to;
1. Put the battery button in the Store position
2. Isolate the batteries from the TT by disconnecting the positive and negative batterie cables going to the TT and protect them from connecting to anything else while they are loose.
3. Unplug the converters electric plug from the back of the breaker panel.
4. Disconnect the positive / negative / ground wires from the old converter and don't let them touch anything else.
5. Plug the new converter into the back of the breaker panel.
6. Connect the positive / negative / ground wires to the new converter
Is this the correct procedure?
Thanks!
Equal-I-zer Hitch
"Roadrunner"
Battery disconnect not turning off Hammertime Sprinter and B-van Forum 10 08-26-2017 06:47 PM
Atwood gas hot water heater not turning off murphy Water Heaters, Filters & Pumps 2 06-27-2014 03:04 PM
Turning off refrigerator before fueling TV kswelsh Refrigerators 29 11-14-2013 06:35 PM
Turning off Sureflow system when connected to city water bonginator Water Heaters, Filters & Pumps 18 05-06-2010 09:37 AM
