Old 02-01-2019, 10:07 AM   #1
2018 30' Classic
Chesterbrook , Pennsylvania
Trying to Understand battery issues
Hi
-2018 Classic 30'; 200W factory-installed solar
-Boondocking in Florida and left trailer for 3 days to visit friends. 100% charged. No lights were left on - only refrigerator running on LP. Good sunlight for 2.5 days - some shade from nearby trees but mostly uncovered.
-When we returned batteries were at 45% charged. Connected 2000w generator and monitor showed batteries at 70% charged. Ran generator for approx 2hrs and batteries reached 80%. When disconnected the generator, the batteries showed 50% charged. Went to bed and woke up to 20% charged - only Alde system was on. Connected the generator and now showing 80% charged.
Questions: It seems the batteries are draining too fast for the amount of use they're getting. And re-charging at a slow rate. Accurate? If so, solution?
Why does the monitor show batteries at 80+% when connected to the generator and much less when disconnected from the generator?
Thanks.
Sweets87 is offline   Reply With Quote
Old 02-01-2019, 11:32 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You didn't say where you were getting the percent of charge. If it is voltage based, it is only correct when the batteries are neither being charged or discharged.
The batteries have internal resistance. When the generator or solar is charging the batteries it has to put out a higher voltage than the battery total cell voltage in order to force current through the internal resistance. On a voltage-based monitor this will indicate an incorrectly high state of charge. When the batteries are discharging the voltage at the terminals is less than the cell voltage due to drop in the resistance. This will indicate an incorrectly low state of charge.
The best way to measure state of charge is with an energy sensing system like those made by Victron and others. You put in the capacity of your batteries and the monitor keeps track of current in and current out to continuously monitor the state of charge. With voltage alone you must charge the batteries, stop charging them and "let them rest" for an hour or so and them measure voltage. During that time there should be only minor, or preferably no, current being drawn.
Is your inverter on? It draws a significant current when on, even if not in use. There are many phantom draws possible depending on equipment, propane detector, subwoofer, and if you have a central control system, that also draws current to mention a few. Don't forget to check storage compartment lights. I'm not up on the newer trailers, so some of this may not apply and other things may. I like my simple system with a mechanical battery disconnect.
The best way to troubleshoot this is to get an ammeter and measure the current being drawn from your batteries. Then pull fuses until you find what draws how much. Once you know the total draw, you can figure out how long the batteries should last.
A 200 watt panel is probably only good for about 50 amp hours on a good day, that means an average current draw of only 2 amps. That is not very much.
Also, 50% state of charge is the lowest you should let your batteries be discharged to. Any more than that is damaging the batteries such that their storage capacity is reduced.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-01-2019, 01:24 PM   #3
Long Island , New York
Welcome to the forum!
No experience with solar, so some general comments . . .
Good advice from Al.
Here is a good Battery School resource for reading up on RV battery care:
http://www.batteriesnorthwest.com/ba...hool.cfm?TID=0
State of charge etc. -- http://www.batteriesnorthwest.com/ba...cfm?TID=5#ANC5
When you leave the trailer, you must minimize all "phantom loads" like the inverter, audio/visual equipment, and so forth. The propane detector draws a small amount, but even with the fridge running on propane, that would not account for your battery drop IMO.
The new search function above in the blue box works great if you are using the desktop version of this site. [The App search function is not so hot apparently IMO.]
"battery phantom loads" -- https://www.google.com/search?q=batt...=airforums.com
Have you contacted your dealer about this? They may have not cared for the batteries well before your purchase. "Lot rot" is a common occurrence unfortunately: https://www.google.com/search?q=lot+rot&sitesearch=airforums.com
I would recommend that you take the batteries into a battery dealer, and have them tested. Are they AGM or lead flooded-cell? If defective they should be replaced under warranty IMO. If only one is defective, insist that both be replaced at the same time with identical batteries.
Good luck,
Peter
PS -- It is possible that your battery charger/converter is not operating correctly, so hopefully someone can chime in with advice on testing for this, or go to a local Airstream dealer in Florida. When did you get the AS, and have you ever let the batteries go below 12.2 volts? If so you might have damaged them.
Old 02-01-2019, 02:48 PM   #4
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Not up to speed on the Alde system draw, but I know my furnace will eat up the batteries, especially if running off/on over more than 24 hours. Once your 12v wetcell batteries are bad, they never recover fully. I would not go 3 days without power without disconnecting the batteries totally from the AS with a mechanical disconnect switch. If I needed power for heat while gone, I would check into an RV park with power...solar could work I suppose, but think you have battery issues.
Likely from what you have said, if they are 12V batteries from Interstate, (??) you have bad batteries. Happens to many of us even with new trailers. It has happened to me personally on my new 2014 25' FC and my 2017 28'FC models; also a close friend with his 2017. I would get my batteries tested first to see if they have a bad cell. Interstate is pretty good about doing this and also typically will replace them if bad. There are several threads on this. Once you eliminate that problem and know your "new replacment batteries" are good, you can troubleshoot the converter, but my money is on the batteries. Few choices to replace them with..ask Interstate about a trade in value for either an AGM, a pair of 6V Golfcart batteries, or perhaps move up to Li if you want the best. I moved to 6V Golfcart batteries and replaced my converter also with a multistage. Your 2018 model has a 3 stage converter now, so don't suspect that is the issue. Could be wrong but start with batteries.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 02-01-2019, 02:48 PM   #5
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
Sweets, from my experience running a generator for only a couple of hours on a 45% state of charge battery would only add about 10% to a battery if its being charged at 13.8V, which is what the stock converter in my 2017 FC25 did. I replaced the stock converter with a PD4655 so when I "bulk" charge with my generator, it charges at 14.4V. Even at 14.4V, I need to run my generator about five hours each day to bring my battery to 80-to-90% charged. It then drops into "absorption" mode and I turn the generator off. So your generator and converter seem to be performing as designed. The design of the Airstream stock generator is to output continuous 13.8V so the converter can stay connected to shore power without overcharging the battery. Therefore, the battery never gets completely charged and it takes days, not hours, to get the battery to 80-to-90% charged.
Now let's move on to the solar. In Fall/Winter, the days are short, the sun is at a poor angle with significant shading, and cloudy skies are prevalent. These are not good conditions for maintaining a battery bank with solar. Even with my 400W, it was barely enough to keep my batteries charged while boondocking in November. I found 200W was adequate in the summer with long days and plentiful sunshine, but not in the winter months.
So lets add the solar and the generator charging together. It sounds to me that you are just taking more juice out of your batteries than the solar and a couple hours of generator charging at 13.8V is putting into your batteries. My solution was to install 400W of solar and a new converter that was capable of putting out a 14.4V. If you want to keep your stock converter and not add watts to your solar system, you may need to run the generator all day in the winter months to have enough battery to run your heat, refrigerator, and lights all night.
You did get very good advice above. Have your batteries tested to make sure they are not damaged. Get an Amp Meter to check your Amp draw. And figure out a plan to replace the Amps you are taking out of your batteries each day.
And yes, I too murdered my first set of batteries in under 11 months in my new Airstream by not realizing that I was taking more juice out of my batteries than my generator was putting in. Then I added the 400W of solar, the PD4655 converter, and a pair of 230AH 6V golf cart batteries which have been happily providing all the boondocking power I've needed ever since.
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 02-02-2019, 08:26 AM   #6
2018 30' Classic
Thanks everyone for the tips/advice. Much appreciated.
Old 02-02-2019, 08:57 AM   #7
Please let us know what you end up doing, and whether the batteries are bad, replaced under warranty, etc. etc..
Good luck,
Peter
Old 02-02-2019, 09:03 AM   #8
gypsydad's Avatar
Yes, agree with Peter...we are always curious about the problem and the outcome... Good luck!
Old 02-02-2019, 09:44 AM   #9
2018 27' Flying Cloud
Atlanta , Georgia
Some additional thoughts:
1. There really is no substitute for a Victron style monitor. With it you can see parasitic draws and overall usage.
2. The original equipment Interstates do not have enough capacity with furnace running to last more than 24 hours. I ended up buying 2 Lifeline AGMs with 100 Amp-hr capacity. They have to be turned sideways but will fit in the battery compartment you have.
3. You can buy 500 Watt-hr lithium batteries with charger and inverter built in for about $500. They weigh only 12 lbs. I have two. They can be fully discharged without damage and can act pretty close to an additional two batteries of the Interstate size which suffer damage after a 50% draw down. I have a 7 AMP smart charger that I connect to the lithium batteries to keep the trailer batteries charged. These lithium batteries can be recharged from any 110 V outlet. When dry camping, there are usually 110 V outlets in the restrooms which I use to recharge them - daily in some cases. A way to fake hookups. :-) I have a front bed trailer so was able to run a 12 V line from the trailer batteries (through a Victron monitor) to the compartment under the bed where I put the lithium batteries and charger. That way the lithium batteries stay warm in cold weather which keep them near full capacity. You could also connect these lithiums directly to the trailer electrical system with a dogbone converter to the 110 V output of the lithiums. but they draw down pretty quickly that way. I prefer going through a charger.
I rarely need to use a gas generator although I have one as a backup. I nearly always dry camp in the "no generator" areas of campgrounds in winter.
This is what I bought, but there are others.
https://smile.amazon.com/Powerpro-Po...hium+generator
jnm30327 is offline   Reply With Quote
Old 02-02-2019, 09:56 AM   #10
Atlanta , Georgia
Incidentally, a great way to make your batteries last when dry camping or boondocking in winter is to turn off the heat at night and sleep in sleeping bags. If it is so cold, you are worried about freezing pipes, then just turn the thermostat way down. When you get up in the morning, the trailer will still heat up pretty fast.
Old 02-02-2019, 10:14 AM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
10/4 on a quality monitor...the Victron,(with remote dongle), was also our choice.👍
Nice not having to go into the trailer during the 'polar vortex'. ❄️
ID:	332830   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 02-02-2019, 10:40 AM   #12
Kyoshi's Avatar
2015 28' International
Beachville , Ontario
Have you tried checking for a bad battery cell. Get a specific gravity battery tester and pop the caps on the batteries. If a bad cell in one or both batteries, then you need new ones.
I had this problem of batteries not holding a charge for more than a few hours ,and that was the problem.
Kyoshi is offline   Reply With Quote
Old 02-02-2019, 11:30 AM   #13
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you left the trailer and the "normal" stuff was running ( in cooler weather on a 30' Classic) 3 days to half power on the batteries is doing very well. In normal use ( = you in the trailer doing stuff) the batteries are good for maybe 24 hours. Even with the sun out, you don't get a lot of solar this time of year. Solar isn't going to stretch those numbers a whole lot.
Some math:
Fridge pulls about 1.1A. Parasitics are about 1/4A. In three days, that's 100 AH all by its self. At 70% capacity (if it's cold out) that's about all you have if you get 10 AH a day from solar.
If the magic control system is turned on, that adds another amp to an amp and a half. You would now need to get 130 AH from solar simply to be at 50% charge. That would be doing well for solar this time of year.
Old 02-10-2019, 07:29 PM   #14
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i agree with the victron post
get some of their systems and get a shunt to measure actual loads.
when the load is on, open the breakers one by one to see where the load is
waninae39 is online now   Reply With Quote
Trying to understand what these "lights" do? Zcashio Lights - Interior & Exterior 2 08-09-2017 01:03 PM
Magnum Inverter, Voltage Drops, Low Battery Cut Off...don't understand 2452bayliner Sprinter and B-van Forum 1 03-01-2017 08:55 PM
Trying to Understand How My Battery Works iHayley Batteries, Univolts, Converters & Inverters 11 07-19-2008 05:26 AM
Now I think I understand ... guy99 Commercial Listings 23 04-03-2006 02:36 PM
Please help me understand what these numbers mean joshua32064 Our Community 18 10-02-2003 07:24 AM
