Old 10-11-2010, 03:05 PM   #1
1973 31' Sovereign
... , Washington
Exclamation trying to bypass the univolt inverter
I am trying to bypass the univolt inverter in my 73 Sovereign but when I disconnect it, the 120v outlets dont work anymore. Is there an easy way to go about doing this. I am only living in the trailer while I build and I don't need the battery back up, so I want to some how shut off the NOISY inverter while still being able to run 120v. Thanks for you help- Chase
acsavage is offline   Reply With Quote
Old 10-11-2010, 03:14 PM   #2
If your not going to use any 12 volt lights, then simply unplug the Univolt.
It has nothing to do with any other 120 VAC circuits.
Sounds like perhaps another problem.
help needed..., inverter, wiring
Univolt Inverter Question snshort Batteries, Univolts, Converters & Inverters 9 04-15-2011 08:36 AM
argosy bypass valves argosy1987 Fresh Water Systems 0 06-17-2010 05:41 AM
Bypass G. Traveler Sinks, Showers & Toilets 3 03-06-2010 08:42 AM
Bypass Univolt with Intellipower? afn10694 Batteries, Univolts, Converters & Inverters 23 06-05-2009 07:18 AM
Bypass Valve tomb Water Heaters, Filters & Pumps 0 11-26-2002 06:42 AM
