Old 02-09-2014, 11:52 AM   #1
2012 25' FB Flying Cloud
Trimetric and Interstate batteries
Hi
I am finishing up installing a Trimetric Battery Monitor on our 2012 FC25FB.
I looked at the factory equipped Interstate Batteries and discovered they are Group 24 but 2 different capacities.
One is a HD24-DP and the other is a SRM-24. To set up the Trimetric I need to enter the amp hour capacity of the batteries. I assume this would be at the 20 hour rate. The Interstate Battery website does not give the 20 hour rate but gives the hours of amp load at 5 amps and 15 amps. This number is different for each battery.
I will contact Interstate Battery and Trimetric tomorrow about this.
Eventually I will replace the Interstate batteries with 6 volt Trojans when I figure out how to make the battery box deeper.
Any ideas out there on the amp hour capacities of these Interstate batteries?
Phil
Scaler113 is offline   Reply With Quote
Old 02-09-2014, 02:01 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I set mine up at 150 amp hours even though my 2 golf cart batteries are supposed to be 220 amps. My reasoning is the capacity drops as they age and the manufacturer probably exagerates the capacity anyway.
I prefer to figure these things on the conservative side. I have never discharged below 50% based on that setting and my batteries will be 11 years old in June
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-09-2014, 08:08 PM   #3
dznf0g's Avatar
Oswego , Illinois
I have forgotten the precise numbers right now, but you can dial in your amp hours and corresponding percentage of state of charge by noting the voltage. IIRC, a 50% state of discharge occurs at a bit over 12 volts...like 12.2. So not only can you determine a relatively true amp hour capacity of a new battery, but you can adjust for aging ones as well.
I need to look up the precise numbers, but that's pretty close I think.
-Rich-
Old 02-09-2014, 10:11 PM   #4
1974 Argosy 20
Kooskia , Idaho
I set mine for 70 amp hours for each of the original type 24 batteries, or 140 AH total. That is approximately right for most type 24's. Close enough anyway. When I put new golf cart batteries in this spring, I will use 220 AH for the set.
Scaller 113, you may find it easier to add height to the original battery box than to deepen it. That is what I plan to do at any rate.
Old 02-10-2014, 09:50 AM   #5
Hi Idroba,
I am planning to eventually install 6volt golf cart batteries. Our 2012 FC25FB has a exterior storage compartment door that hinges at the bottom across the front of the trailer. This door opens down to near the top of the battery box so I do no have much clearance to increase the height of the battery box by coming up. I have to take some precise measurement and may end up extending the box downward.
Thanks for your input.
phil
Old 02-10-2014, 12:01 PM   #6
1974 Argosy 20
Kooskia , Idaho
Ah, that front storage compartment does make for a problem in raising the top of the battery compartment. My FC 20' does not have that issue.
Interstate charging system - BIM confusion! wayneskid Sprinter and B-van Forum 23 01-17-2017 05:04 PM
One of the batteries died HiHoAgRV Batteries, Univolts, Converters & Inverters 3 08-22-2011 01:48 AM
