Old 10-05-2016, 12:03 AM   #15
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I didn't like the trimetric box either, and I didn't want it to be "surface mounted", so I took an aluminum plate and mounted the trimetric panel to the plate and then "back mounted" the the plate to the cabinet:
See Post 12
http://www.airforums.com/forums/f116...ty-141874.html
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 10-05-2016, 04:37 PM   #16
2005 19' Safari
ishpeming , Michigan
I just want to say how much I appreciate the feedback from all of you in regards to this project. I just about finished today and just have to do the final wiring tomorrow. If I could figure out how to post pictures I would. Until then, this is how I did it. Essentially I grabbed the inbound +/_ as it came inboard, from the battery box, under the street side seat of the dinette. Positive goes to a battery disconnect solenoid and ground goes to a bus bar. I pulled ground off the buss bar and wired it into one side of the shunt. From the other side of shunt back to bus bar. Ran signal cable behind water tank, under sink and into wardrobe up behind two floor drawers. I cut a hole in bulkhead to left of stove and below Airstream info center. I threw away TriMetric's box and did a flush mount instead of a surface mount. Tomorrow I will go out in search of a piece of aluminum and create a trim plate for a look similar To Mark's. Woody
amazingwoody is offline   Reply With Quote
Trimetric battery monitor install mpsgolf Batteries, Univolts, Converters & Inverters 1 09-28-2016 05:52 PM
Battery Disconnect and Tri Metric 2030 controller installation jbxx Generators & Solar Power 17 09-06-2015 04:58 PM
Trimetric 2030 Shunt location jbxx Batteries, Univolts, Converters & Inverters 6 01-21-2015 07:39 AM
xantrex linklite vs trimetric 2025A battery monitor demondeacon3 Batteries, Univolts, Converters & Inverters 8 03-17-2012 06:55 AM
New Trimetric RV Battery monitor 68 Overlander Commercial Listings 14 04-15-2009 11:14 PM
