Old 02-25-2005, 02:00 PM   #1
Trimetric 2020 meter
I recently installed a Trimetric 2020 meter to monitor battery voltage, amperage, amp-hours remaining, and several other useful parameters of our two group 27 batteries. The meter is made by Bogart Engineering, and I purchased it through Back Woods Solar at www.backwoodssolar.com as a kit for $190. I will shortly fit the optional lightning protector. These were very helpful people, and the install went without a hitch. I used the 100 amp shunt for greater accuracy than with the 500 amp shunt. I consider it an excellent instrument. Prior to buying the meter, I noticed that the two batteries would only last about 4 days when not attached to 120 v shore power, even when the trailer was unoccupied, and only the refrigerator was running, but on propane. Using the Trimetric 2020 I found that the current drain in the 1988 Excella was 1.30 amps. At 31.2 amp-hours a day, and reckoning on about 50 usable ah from each battery, then they would clearly be run down after 3 days. I traced the consumption of 1300 milliamps by switching off one appliance at a time. The results were:
Charging cellphone 70 ma
Climate control on Dometic refrigerator (forgot to switch off!) 490 ma
Refrigerator without climate control 310 ma
(Refrigerator with climate control therefore 800 ma)
Propane detector 40 ma
Jensen radio on standby 230 ma
Display panel over front couch 130ma
Trimetric 2020 meter 30 ma (16 ma with display off, according to the manual)
These total 1300 ma, and I will be taking steps to reduce this total. Remembering to switch off the climate control would be the easiest fix. I will be looking at fitting switches to the radio and the display panel. This has the disadvantage that clocks and selected wavelengths will need to be reset. I will also use the tow vehicle battery when I need to charge the cellphone when boondocking. I will investigate the feasibility of running the refer in limp mode, with battery power disconnected. Other intermittent loads were:
1 incandescent 1141 bulb light 1370 ma (Compact fluorescents are on the to-do list!)
Water pump 4100 ma
Furnace 6470 ma
12v TV 2400 ma
Radio on 70 ma
Stove vent fan 1650 ma
Bathroom vent fan 2250 ma.
I recommend the Trimetric 2020 meter. Used in conjunction with an Intellipower 60 amp charger and Charge Wizard, its ability to monitor amp-hours remaining as well as current and voltage gives me the knowledge I need to maintain and use the batteries.Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 02-25-2005, 02:50 PM   #2
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
trimetric
Great post Nick
I've been looking at the Xantrex Battery Monitor which probably does about the same things as you trimetric. Also on my list of things to do this spring is install the intellipower with charge wizard.
Thanks for the input. Let us know how the intellipower is working.
Mark
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 02-25-2005, 03:04 PM   #3
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Radio on 70 ma
Huh? In that case it would be better to leave the radio on than in standby.
Maurice
Old 02-26-2005, 07:49 AM   #4
Maurice, that's 70 ma above the existing 230 ma on standby, making a total of 300 ma when the radio is turned on. I must be more precise!
Mark, the Intellipower is much quieter than the standard charger, and obviously far better in terms of its 4 stage charging for battery maintenance and longevity. However, at certain loads the cooling fan would cycle on and off about twice a second, with a sound like a trotting horse. The manufacturing company told me that that this feature has recently been removed by the installation of a variable speed fan. The unit was exchanged under warranty about 2 weeks ago, and the new unit is operating satisfactorily. I highly recommend this product. Thank you for your feedback on this thread. It's always good to know that one's slow and stumbling typing is of some interest to someone! Nick.
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
7.3 Meter Minuet on Ebay hotLAVA All Argosy Trailers 0 05-20-2003 08:48 AM
Electric meter dienst1 Airstream Motorhome Forums 4 10-20-2002 09:17 PM
Electrical testers, and meters thenewkid64 Electrical - Systems, Generators, Batteries & Solar 7 08-10-2002 08:01 PM
Meter for amps davidz71 Electrical - Systems, Generators, Batteries & Solar 5 05-09-2002 10:21 AM
