Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 01-27-2007, 04:50 PM   #1
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Trimetric 2020
There have been a few threads regarding Bogart Engineering's Trimetric 2020. A friend called me today and said that he ran across a site Infinigi - Infinite Energy Solutions that had the Trimetric on sale for $155.72. They also had some 12 v. LED floodlamps housing 18, 45 and 99 LED's.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-29-2007, 09:52 PM   #2
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
We've had it at $139 for about a year now. You must have a shunt to make the Trimetric work so that adds about $30.
Old 01-30-2007, 09:04 PM   #3
davidz71
davidz71's Avatar
Hi Randy,
I noticed the Trimetric on your website shortly after my post. Glad to see that you carry it. One question, when my purchase of the SunRunner 100/22B system with one 100 watt or two 100 watt solar panels and HPV-22B boost regulator occurs in April, will the Trimetric 2020 give me any more additional information on my system?
Craig
AIR #0078
3.73 rear end
Old 01-30-2007, 09:29 PM   #4
68 Overlander
Commercial Vendor
Images: 21
Hi Craig,
I suppose that depends on how you look at it. The Trimetric will not display anything unique about your solar input per se other than the total amount of amps, cumulative amp hours, voltage, etc that it already displays. As long as the solar charge line is connected to the shunt, it will read it but will not indicate; this came from solar and that came from you charger, if that makes sense. You can isolate one or the other if you wanted to measure which source was providing the charge, that would not be hard.
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Which Brake Controller???? blrpix Brakes & Brake Controllers 32 10-21-2005 04:13 PM
Trimetric 2020 meter nickcrowhurst Electrical - Systems, Generators, Batteries & Solar 3 02-26-2005 08:49 AM
has anyone measured phantom loads? soultrip11 Electrical - Systems, Generators, Batteries & Solar 2 02-24-2005 09:21 AM
jordan 2020 brake controller 57overlander Brakes & Brake Controllers 5 11-25-2004 08:10 PM
test
