Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 02-18-2003, 08:39 AM   #1
Profile:
Trickle charger to replace Univolt
I am living permanently in my 31' Sovereign. The Univolt was not working (had an electrician check it) so I removed it. I only need the 12 volt system for overhead lights so I connected a 12 volt trickle charger which puts out 12 amps to the wires that go the lights and this has seemed to work fine. I'm still a little nervous about this. Does anyone forsee any problems? Thanks in advance for the help.
jwaldin is offline   Reply With Quote
Old 02-18-2003, 09:36 AM   #2
Profile:
Trickle Charger
Those univolts are expensive, but they do keep the DC voltage from going too high and doing battery damage. Some chargers have limmited cut out circuits, in fact, I have a little one that will take a battery up to 15 volts plus.
I changed out my univolt, after replacing the capacitors a couple times, with a regular trailer convertor. Something left over from a used camping van we had. But I keep an eye on it. With a Radio Shack digital voltmeter and a cigerate lighter plug, you can monitor the voltage to the tenth of a volt. Mine hovers around 13.2 volts Gives me pease of mind and now costs about twenty bucks
Good Luck SteveMc
Steve McCarter is offline   Reply With Quote
Old 02-18-2003, 11:12 AM   #3
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
I'd hardly call a charger that puts out 12A a trickle charger. Most of these have no filtering. While this might not be a problem with tungsten lights, I wouldn't want to use it with no batteries with flourescents or electronic equipment.
I have a 55A Magnetek that's only been used for about 7 months. If I could get $120 (shipped in the 49 states) for it, I'd pull it out sell it so I could put a fancier unit in there.
The literature says it's okay to run it on your appliances without a battery load being connected.
Maurice
AB8XA
AIR # 804, WBCCI 5446
The Long, LONG Trailer
Paralleled Honda EU2000i
need help on univolt converter 72 Overlander 1 Electrical - Systems, Generators, Batteries & Solar 90 06-25-2009 12:55 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Solar trickle charger.... drboyd Generators & Solar Power 27 09-20-2003 08:51 PM
Removing Old Univolt & Installing New Intellipower 9160 montanaandy Electrical - Systems, Generators, Batteries & Solar 3 07-15-2003 12:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 09:26 PM
