Old 10-28-2006, 06:10 PM   #1
1971 31' Sovereign
Joseph , Oregon
Trailer plug
We need to replace the plug on the trailer end and would like to have the schematic or at least the the color codes for the wires behind couch. A few loose wires I am not sure go where?
Larry and Nicole
trea is offline   Reply With Quote
Old 10-28-2006, 06:17 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
here is what I use
'77 Sovereign Intl 31' CB
Old 10-28-2006, 07:31 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Also see Airstream FAQs on this subject. That's what's coming out of the trailer. See http://www.marksrv.com/wiring.htm also. Make sure you have functions lined up -- the mirror image matching can cause some mixing up.
5 meter Langford Nahanni
Old 10-31-2006, 07:46 AM   #4
1971 31' Sovereign
Joseph , Oregon
Put new plug on but it seems as though we should replace the contector right at the trailer. After taking the cover off from inside the trailer to look at what we have I noticed that not all the colors match what we have on the outside run. There is also a white wire (ground?) that is loose but not sure if this is correct.
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum Admin, News and Member Account Info 2 10-15-2002 06:38 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Trailer Life RV Campground Finder Pahaska Our Community 12 08-03-2002 08:45 AM
