Old 03-21-2015, 05:23 PM   #1
1973 25' Tradewind
Beautiful , Oregon
Trailer Microwave getting hot
I have a Microwave in my trailer question. I ran a dedicated line 12 gage to a 20 amp GFI for the microwave that replaces the oven. The Tradewind has a 30 amp service. The Panasonic microwave is 1200 watt. I ran it and the outside seemed to get hot. A little hotter than I would think normal. After several seconds it seemed to change sound like it was getting bogged down. Very slightly but it did change sound. So I then tried it outside the trailer and it was the same thing, including the sound. It did not trip the breaker in the trailer. I ran it in the trailer for only 2 minutes. It had a little smell but it is brand new microwave. There was nothing in it, if that matters
An advice? Should I be concerned? Is the 1200 watt too much? I did have the trailer plugged into 20 amp shore power so I don't know if that was it except it did it plugged in outside the trailer too on a 20amp circuit, only thing running on it.
Any help would be appreciated
Tony
Tony S is offline   Reply With Quote
Old 03-21-2015, 05:37 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Sounds normal to me. Try it with a cup of water or something else.
MICHAEL
Old 03-21-2015, 05:43 PM   #3
2005 19' Safari
GLENDALE , AZ
URGENT NOTE! -- Do NOT run a microwave with nothing in it!
The microwave energy is not absorbed (into food) and will reflect back into the Klystron tube, which will ruin it.
Hopefully, you have not permanently damaged your new microwave oven.
Old 03-21-2015, 06:42 PM   #4
1973 25' Tradewind
Beautiful , Oregon
oops I hope not too yikes
Thanks I will see if it boils water in a cup
Wattage I take is ok for my set up?
Tony
Old 03-21-2015, 09:58 PM   #5
2005 19' Safari
GLENDALE , AZ
A 1,200-watt microwave draws about 10 amps, which is within the 20 amps available. This assumes you are connected to a 30 amp RV connector, and your microwave is connected to the 20 amp GFI described in your original post. However, if you are using a 15 amp adapter to connect your shore power cable to a 15 amp outlet on your porch, patio, etc., the maximum power available will be 15 amps (or a little less). Similarly, if you are using a generator, the maximum power will be limited by the maximum output of the generator.
From your description, I am unsure whether you have a total of 20 or 30 amps available to your Tradewind. Regardless, you may need to limit the total amperage simultaneously drawn via your shore power cable. Specifically, while your microwave is running, you may need to temporarily turn one or more of the following OFF:
* Air conditioner or heat pump
* Heat strip in the air conditioner
* Portable electric resistance heater (Dyson, Vornado, etc.)
* Hair dryer
* Electric coffee brewer, tea pot, electric skillet, or other cooking appliances
To avoid tripping circuit breakers, just make sure that the total amperage (i.e., watts) drawn by all devices that are ON simultaneously does not exceed the available power.
Old 03-21-2015, 10:27 PM   #6
1973 25' Tradewind
Beautiful , Oregon
Yes thank you. That is how I had it figured it. Fortunately I didn't mess up the microwave using it without anything in it.
But the fly in the ointment now is that it says on the back it can be enclosed in a cabinet but not used within two feet of a stove. I have it designed in below the stove so it maybe back to the drawing board ,or at least, the store.
It is a shame because it looks so good in its spot. I figure the Microwaves made for RV with the higher price tag are specially designed to be used close to the stove top. Either that or the precaution is over stated but I wouldn't bet on it.
If anyone knows about the microwave situation above I would love to hear what you know.
Again Thanks for your responses
Tony
Old 03-21-2015, 10:52 PM   #7
2005 19' Safari
GLENDALE , AZ
I suspect the requirement about not mounting too close to a stove relates to heat from the gas oven, or rising from a burner located beneath the microwave, overheating the electronics in the microwave oven.
If you use your microwave like many of us do (i.e., primarily to reheat coffee, leftovers and prepared foods; and not so much for actual cooking); and, while in use, the microwave chassis won't be hot due to its close proximity to a pot left simmering for an extended time, or from baking something in the oven, you will probably be OK.
It sounds like the microwave is mounted underneath the stove burners. Here are a few additional questions:
* Is the microwave also beneath the stove's oven?
* Do you use the gas oven to cook? (Ours is used for storing bread, chips, cookies, etc.; and it's more like a small pantry. In fact, our oven has never been lit.)
* Will you use the microwave while the gas oven is on?
Depending on your answers, your microwave location may be OK. However, a photo of your installation would help others provide more accurate advice.
Old 03-21-2015, 10:55 PM   #8
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Physics : Heat rises , Microwave under stove top should be OK.
To prove that remove the microwave, turn on the stove with a pot of water on it and boil the water, check the temp under the stove, it should be cool.
If it is reinstall the microwave and enjoy.
If not install a cookie sheet under the stove with an air gap and test again.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 03-22-2015, 09:07 PM   #9
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Just a thought....and a biology experiment.
Take 2 separate cups of water. using two, identical houseplants, microwave one of the cups of water and allow to cool. Water each plant, repeat using cool microwaved water on one of the plants as needed. Guess which plant will die. If it wont hydrate a plant, it will not hydrate an animal (Kingdom). I love the magic chef oven
NavyCorpsman is offline   Reply With Quote
Old 03-22-2015, 09:27 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Quick sidebar - according to Snopes, the microwave experiment on watering plants appears to have been faked (they also ran one with undoctored pics). I haven't tried this on my own so can't vouch either way...I am a fan of Snopes though :-)
http://www.snopes.com/science/microwave/plants.asp
Old 03-22-2015, 11:17 PM   #11
1973 25' Tradewind
Beautiful , Oregon
Good Idea Phoenex Here are a few pictures of the microwave cabinet. It doesn't show the unit but I think it can be seen stove top above the larger cavity with curved front. There is also the water heater near by, below. There is also the new Suburban furnace behind the doors with the expanded aluminum to the right.
We haven't to this point used the old microwave or the oven/range we took out much. We usually heat things if anything in the microwave. Frankly, I am not big on cooking inside. I suspect with the remodel I may remain reluctant.
I believe the worry is a leaking gas and not heat.
Tony
ID:	234782   Click image for larger version
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 10:58 PM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
AC, Microwave, Elec Hot Water Heater, TV = Blown Fuse KJRitchie Electrical - Systems, Generators, Batteries & Solar 36 09-10-2013 12:57 AM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
