Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-13-2002, 02:35 PM   #1
Profile:
Trailer lights
I am in the last stages of getting our 1971 Safari on the road. Just had a brake box installed on the truck and a seven wire connector. Everything seems to work ok. However, I have one question. The outside rear red lense light stays on all the time that the seven wire connector is connected to the truck. Even when the lights are turned off and the truck is not running. The brake lights and directional signal lights work good, they are the middle lights on each side of the trailer. The inside light is just a reflector. Anybody got any ideas if this is correct or not.
Dan
Dbraw is offline   Reply With Quote
Old 09-13-2002, 05:51 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
dan,
I would suggest you check the wiring inthe pigtail taht connects the trailer and truck together. It sounds like there may be a wire crossed that is feeding the truck charge line to the brake lights.
Good luck
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 08:50 PM
Trailer lighting question-Exterior Sneakinup Lights - Interior & Exterior 2 12-02-2003 06:52 PM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 02:43 PM
How do I test trailer exterior lights? Bryanhu Lights - Interior & Exterior 2 08-09-2003 07:27 AM
Getting Close! kamadeca Our Community 48 02-05-2003 09:56 AM
