Old 02-18-2014, 11:20 PM   #1
2004 30' Classic Slideout
Denver , COLORADO AND West Yellowstone, MT
Trailer Brake Power
Are nthe AS trailer brakes powered by the "House Batteries" or from the tow vehicle umbilical cord??
montanapat is offline   Reply With Quote
Old 02-19-2014, 01:04 AM   #2
68Streamline's Avatar
Cerritos , California
From the tow vehicle batteries.
68Streamline is offline   Reply With Quote
Old 02-19-2014, 02:47 AM   #3
r carl's Avatar
Lin , Ne
The break away switch is powered by the house batteries.
Old 02-19-2014, 08:05 AM   #4
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
This is the third post of the same question worded differently. Try combining them into one thread so the answers will be all together. Running lights, tail lights, and brake lights are powered from the TV. Breakaway switch for brakes in case of catastrophic failure is powered by house battery. To legally tow YOU MUST HAVE BOTH UMBILICAL CORD TO TV TO POWER RUNNING LIGHTS AND A FULLY CHARGED AND CONNECTED HOUSE BATTERY.
panheaddale is offline   Reply With Quote
Old 02-19-2014, 08:56 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Do you have an umbilical cord on the trailer with a 7 pin plug on it? Do you have a 7 pin receptacle on the truck and a brake controller in the truck?
If you have the truck wired take a volt meter and read between the 2 lower pins on the truck receptacle while someone steps on the brakes and then moves the manual handle on the controller. If you see voltag in each of these 2 experiments the truck is fine.
Connect the umbilical cord. With a compass held to the wheel and close to the bottom of the brake drum see if the compass needle moves when someone applies the brakes. This will test the complete electrical system of the brakes. It does not mean the brakes are adjusted correctly or the mechanical parts are good. Removal of the brake drum and visual inspection is next.
2004 Excursion 4x4
Disc brake lag trvler Brakes & Brake Controllers 50 01-15-2012 11:55 AM
Connecting Trailer Brake Controller on 2008 Interstate solar-guy Sprinter and B-van Forum 4 08-10-2011 11:10 AM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
