Old 05-18-2010, 08:16 PM   #1
1976 25' Tradewind
1962 22' Safari
1953 25' Cruiser
New Salem , Massachusetts
Tradewind ac panel
We just bought a 76 Tradewind. When we viewed it before buying, it was hooked into a dedicated 30 amp exterior receptacle. There was no battery in the trailer. All of the circuits worked fine. After we bought it I installed a battery while it was still connected. Again all worked fine. when discnnected from shore power all of the dc circuits appeared fine. The running lights all worked when I towed it home.
Once I got it home, I used an adapter to plug the trailer into a 15 amp GFCI outlet. It immediately popped. I tried a different GFCI on a seperate circuit. it popped as well. I even tried it with all of the breakers in the trailer off and it still popped.
The plug and cable looked new even so I tested it and found continuity between the neutral and ground. I opened the breaker box and discovered that the frame and shell ground was hooked to the neutral bus. It effectively bonded the ground and neutral which was causing the GFCI to pop.
It appeared that at some point someone moved the heavy copper wire from the ground bar to the neutral bar, probably when the cable was changed. I moved it back to the ground bar and when I plugged the GFCI all was well.
Attached is a picture showing the as found condition.
Name:	power panel as found.jpg
ghvoelker is offline   Reply With Quote
Old 05-18-2010, 08:31 PM   #2
Images: 59
Six out of ten* electricians do it that way. The other four have travel trailers or motorhomes and know better.
*non-statistical average.
ground, neutral, shorepower
used panel bimpy Ribs, Skins & Rivets 4 11-15-2009 10:41 AM
Where is the Low Voltage Distribution Panel on a '69 Tradewind? monah Lights - Interior & Exterior 1 04-13-2009 05:23 PM
Where's the 12Volt Fuse Panel 72 Tradewind RichHog Batteries, Univolts, Converters & Inverters 3 03-15-2009 06:55 PM
1975 25' Tradewind Lower Corner panel and rock dings Pepsi Ribs, Skins & Rivets 4 02-08-2009 10:48 AM
Panel or not Over59 Ribs, Skins & Rivets 6 10-07-2004 12:20 PM
