Old 03-26-2016, 02:06 PM   #1
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
Tow Vehicle Voltage/Converter
I recently purchased a 2015 RAM 1500 EcoDiesel and was somewhat surprised to see that it came with a 230Amp alternator. In reading the threads on the charge provided by the TV I have one unanswered question. Does the voltage from the TV pass through the converter prior to battery? There were statements that one should be cautious about increasing charge voltage (larger gauge wiring) from TV for it can fry the house batteries. Wouldn't the converter adjust the charge to the battery bank?
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 03-26-2016, 02:15 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Nope, converter has nothing to do with charging from the TV; that is a direct connection.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-26-2016, 02:32 PM   #3
1986 31' Sovereign
Miami , Florida
Changing the wire size cannot change the voltage but it will enable the trailer to pull more amps if they are available. As Larry said, it is a direct connection between the TV alternator and the batteries and nothing to do with the converter.
It is pretty unlikely that you will overcharge your trailer battery while towing.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-26-2016, 03:42 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Mike
X2
If the V regulator in the alternator is working properly and the TV battery is in good condition....no over chg concern.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
1968 Airstream Tow Vehicle Connection and Low Voltage Schematics BuffaloJoe 1965-1969 Sovereign 2 05-26-2013 07:46 PM
converter DC voltage varies A W Warn Batteries, Univolts, Converters & Inverters 5 08-06-2012 04:44 PM
Over voltage from my converter THEMACS3 Batteries, Univolts, Converters & Inverters 8 05-13-2012 01:20 PM
Low voltage... converter or battery problem? patrickdylan Batteries, Univolts, Converters & Inverters 5 08-22-2009 09:24 PM
Voltage Converter or not? SoccerFolks Batteries, Univolts, Converters & Inverters 5 10-09-2004 11:50 AM
