Old 03-26-2017, 01:50 PM   #1
willyjay's Avatar
2010 27' FB Flying Cloud
Burnaby , British Columbia
Tow vehicle electrical hook up
We live in the Pacific northwest and our trailer is stored outside. We have a 2010 Flying Cloud 27FB and are towing with a 2010 F150 super crew. I have noted that initially I am having difficulties getting a good electrical connection to the truck. I am assuming that there is likely some mld corrosion of the power cord plugs over the winter. This usually resolves after unplugging and plugging in the cord to truck 3-4 times. However I am wondering if someone else has had this problem and if there is a solution.
willyjay is offline   Reply With Quote
Old 03-26-2017, 01:54 PM   #2
Boxite's Avatar
2008 22' Sport
Home Depot (and probably many other big box stores) carries an electrical-anti-corrosion-grease called "Ox-Gard". It is a graphite-type-grease which is specifically designed to keep electrical connections from oxidizing (corroding).
It is sold in all sizes, including very small toothpaste-type tubes. You only need a very small "dab" inside your female connector to last your lifetime.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 03-26-2017, 01:55 PM   #3
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
WJ-
Try cleaning/burnishing the contacts the best you can on both the F150 receptacle and the Airstream plug-in. You can then also put some dielectric grease (be generous) on both ends, and that should help the recurring corrosion, and make an excellent connection.
Hope this helps.
On edit - Boxite and I were minutes apart, same recommendation.
ShinyPete is offline   Reply With Quote
Old 03-26-2017, 01:59 PM   #4
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Craig DeoxIT GOLD contact enhancer spray 5% strength works great in cleaning up the contacts. If that doesn't work there might be other problems
Mattirs is offline   Reply With Quote
Old 03-27-2017, 11:25 AM   #5
1975 Argosy 22
Eugene , Oregon
This connector will solve your problems. I live in the NW, Oregon, and have installed this on my TV and trailer.
http://www.ezconnector.com/
Look it over - also available to view on youtube.
mrdfred is offline   Reply With Quote
Old 03-27-2017, 07:26 PM   #6
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
The tines on the AS 7-way plug tend to spread out over time and can be bent inward to enhance contact with the TV male pins. Clean any corrosion, apply dielectric grease and you're good to go.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 03-27-2017, 07:33 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
What do you do with the trailer connector when not plugged into the TV? I have a "socket" that mounts to the trailer A-frame that keeps the contacts out of the weather. My 25 had one, the 30 did not and I added it.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-27-2017, 09:28 PM   #8
2016 25' International
Deerfield , Massachusetts
Al
I have a little hangar (maybe bought it at Camping World?) that zip ties to the jack post and holds the 7pin plug under a little roof.
I smear dielectric grease on/in the plug for long term storage.
thiel is offline   Reply With Quote
Old 03-28-2017, 06:39 AM   #9
2017 25' International
Joliet , Illinois
CorrosionX is outstanding for your trailer plug. Doesn't collect dirt like dielectric grease either.
bel73 is offline   Reply With Quote
Old 03-28-2017, 10:47 AM   #10
Carter Lake , Iowa
My Solution to Chevy TV Elec Connection Reliability Issues
I agree with the other troubleshooting comments posted above, and want to add that I was having perceived problems with the electrical connection reliability until having a discussion with Colonial AS Tech desk. They advised that newer Chevy TV's can have a problem with connection reliability when the pigtail is plugged into the TV rear bumper receptacle WHILE the truck was running. Since that conversation, I have always plugged in while the truck, a 2016 Silverado 2500HD Duramax, was turned off. The problem disappeared, so even though you have a Ford TV, it is something to consider.
2016 Flying Cloud 25' FB
Carter Lake, Ia
GeMeiner is offline   Reply With Quote
Old 03-28-2017, 06:40 PM   #11
willyjay's Avatar
Thanks to all of you for the suggestions
I will look into them
Regards
Willyjay
My Hook Things Won't Hook Sbb Rock Guards, Segment & Window Protectors 2 04-12-2015 06:16 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
Electrical grounding problem with AC hook up Mr. D Mechanics Corner - Engines, Transmission & More... 3 09-02-2008 04:20 PM
Electrical Hook up Question. Gael79 Lights - Interior & Exterior 14 04-27-2008 10:20 AM
how do you hook up electrical? rama777 Electrical - Systems, Generators, Batteries & Solar 22 10-09-2006 03:16 PM
