Old 06-02-2015, 03:38 PM   #1
1989 25' Excella
Torrington , Wyoming
Totally Baffled!
I know I need to carry extra fuses. I opened the fuse box to see what I need to purchase. What is concerning to me is how do I remove these fuses? Do I just pull on them and they pop out? Can I damage anything?
I did look fuses up in the manual. All I discovered is what fuse regulates what system...nothing else.
HighPlainAS is offline   Reply With Quote
Old 06-02-2015, 03:44 PM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
A picture would help. There are several different types of fuses, and I don't know what kind you have. Our 1966 trailer has the old glass fuses, and yes, you just pull on them.
Old 06-02-2015, 03:50 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yes, either kind just pull them out. A dedicated fuse puller can make it easier but is not necessary.
MICHAEL
Old 06-02-2015, 03:53 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I think by '89 they used modern blade-type ATO fuses like this:
They just pull straight out. If you can't grip the fuses with your fingertips, there are cheap plastic pullers for these that you can pick up at any auto-parts store and probably most hardware stores.
— David
Old 06-02-2015, 03:54 PM   #5
1989 25' Excella
Thanks! I look at those little suckers and cringe thinking about tugging on one. I haven't done it before..as you can tell! But now that I know it is okay I'll do it. Rather try now when it isn't a critical need. Far less "blue smoke" in the air.
Old 06-02-2015, 05:43 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Before you pull too hard on a stuck fuse make sure you have a spare, I was pulling fuses to figure out which controlled a light, when it came out one of the blades had pulled from the plastic. Be warned if you see fuses that do not have contrasting colored numbers, it could be a chinese "almost" like a Buss ATO. Best guess is that they forgot to put the dimple in the blade to make it impossible to pull apart like the Buss.
Old 06-02-2015, 05:47 PM   #7
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
They sell "fuse pullers" specifically designed to remove these.
Old 06-02-2015, 05:50 PM   #8
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Or just use your needle nose pliers. Jim
Jim Flower is offline   Reply With Quote
Old 06-02-2015, 09:16 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Silly question, perhaps... do you know what a 'needle nose' plier is?
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-02-2015, 09:47 PM   #10
1979 23' Safari
Wayland , New York
Needle nose plier, the wife standing behind needling into your business, poking you and constantly trying to plié information; what are you going, are you done yet, are you sure that's right?
Old 06-02-2015, 09:55 PM   #11
1974 Argosy 20
Kooskia , Idaho
For your spare fuses, do as suggested in one of the other posts, be sure to get quality fuses from an auto parts place, not the ones from HF or some of the other inexpensive stores. I am NOT a HF basher at all, but their fuses are not good quality and can come apart in your fingers on insertion or removal. Even the best quality fuses are quite inexpensive.
Baffled by 1964 Bambi II taillights motrbungalow Electrical - Systems, Generators, Batteries & Solar 7 04-17-2013 06:50 PM
Suddenly totally baffled by hitches .. clock ticking redwoodguy Hitches, Couplers & Balls 100 12-10-2011 01:56 PM
Baffled by P2 Brake Controller Goal15 Brakes & Brake Controllers 13 05-15-2011 08:11 PM
