Old 10-12-2015, 01:55 PM   #1
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
To throw or not to throw, the breakers
Weíve all pulled into a campsite and found the circuit breakers to be thrown (turned off) on the pedestal, so here are my proís and conís on this.
Reasons to leave the circuit breakers on:
1. Sign on pedestal says LEAVE CIRCUIT BREAKERS ON (Iíve often seen this).
2. Newbie bothers host with complaints that thereís no electricity at their site (you know it happens).
3. You have to throw on the breakers to have electricity at your site (youíve done this).
4. Constant throwing on and off circuit breakers eventually weakens the breaker resulting in premature tripping (heard that somewhere).
Reasons to turn the circuit breakers off:
1. (please fill in blank)
StreamDog is offline   Reply With Quote
Old 10-12-2015, 02:11 PM   #2
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Circuit breakers off
When one connects a plug with a lot of voltage and amperage, there is inevitably an arcing of the contacts as the plug is inserted. The circuit breaker/switch is designed to minimize risk during connection and IMO should always be off when the RV line is plugged.
Also, should one have an unforeseen connection with the metal plugs as they are inserted, with the breaker off this is of no concern. Breaker on and one could find themselves dead or severely injured by electrical shock. Most of us are standing on the ground when we plug in, so....
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is online now   Reply With Quote
Old 10-12-2015, 02:29 PM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I don't care what a sign says. If breakers are on when I arrive I turn them off, plug in my circuit tester and fault detector, wait the 145 seconds for it to check everything and tell me all is ok, then I plug in our wire from the AS.
When I leave I turn the breakers off prior to pulling plug.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-12-2015, 02:42 PM   #4
2016 30' Flying Cloud
Oviedo , Florida
Most circuit breakers are not designed or intended to be used as switches and I believe the NEC prohibits their use as such unless specifically marked as intended for that (SWD). It will cause the breaker to fail quicker, although it is debatable what the life derating actually is.
Unless one is in the habit of connecting to the pedestal with the AC, microwave & water heater on, there is not a huge amount of current to cause destructive arcing.
Worrying about the risk of electrocution while plugging into the pedestal strikes me as right up (down) there with getting killed by a meteor. There is a much higher chance of slipping and falling in the shower and hitting your head, but I don't think most of us would advocate wearing a helmet in the shower
My personal opinion is both the wear and safety arguments are fringe concerns. The bigger issue is convenience and making it easier on the hosts since you would be amazed the number of folks who don't think to check the breaker when they hook up.
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 10-12-2015, 02:54 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have never seen a sign saying leave the breakers on, in fact just the opposite. Plug in both ends and flip the breaker on. Prevents arching and sparking at the trailer plug end. Common sense to me.
MICHAEL
Old 10-12-2015, 04:16 PM   #6
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Breakers off both before I plug in and unplug to avoid arky-sparky. Particularly important in 50 amp as it can create damage if negative lead disengages before positive leads. The only leave on stickers I have seen are for the occasional 20amp that power the sight lights (overhead or pedestal) or a heat tape for the water riser.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 10-12-2015, 06:36 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Breaker OFF all connections made before energizing the circuit. Breaker OFF before disconnecting.
IT COULD LITERALLY BE A LIFE SAVING PRACTICE!
I have only been in one privately owned RV. Park where there was no way to shut the power off at the pedestal.
In that case one should shut the main breaker off in the coach. But that will not prevent you from getting electrocuted while plugging in or unplugging.
Old 10-12-2015, 07:09 PM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
To be honest, I have never worried about it (maybe I'm way too lazy!)
I just plug in and then ask my "Mrs" to tell me if both lights are lit on the polarity checker that I keep plugged in at the galley 110 outlet in the trailer.
If they are on, great, if they are not on, then I check the breaker at the post and flip it on if needed - usually no need, as the last occupant has usually left it on anyway!
Again, not to say that this is the way to do it by any means ..... and I will accept any criticism and perhaps even change my ways .... but it's what I do! A a rule, all major power consumption devices such as AC, water heater, etc., are off when I plug in, so no significant current flow anticipated.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-12-2015, 07:26 PM   #9
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I always shut them off before connecting my Progressive Dynamics surge protector and tester. I wait until it cycles through and tells me nothing is wired incorrectly BEFORE unhitching. If the site's electrical is a mess, I want to know that before setting up.
But I think the procedure should change. I start that way, then connect my 30a cord to my trailer receptacle and then plug in to the PD box - but at that point, the breaker and PD box are on. Even though nothing significant is on in the trailer, it may be worth testing first, then shutting the breakers off, then connecting the cable and then turning the breakers back on to avoid any risk of electrocution. Will think about that for next season.
SteveSueMac is online now   Reply With Quote
Old 10-13-2015, 08:24 AM   #10
Zil
egg harbor city , South Jersey
Electrocution at a power pedestal is a real danger.
Zil is offline   Reply With Quote
Old 10-13-2015, 11:46 AM   #11
2014 27' FB International
Clearwater , Florida
I deal with high amperage equipment for a living, not to mention running the vacuum around the house.
This relates to the AS how?
Best practices.
1) Turn off the shore powered items in the trailer prior to disconnecting shore power.
This reduces load at unplug and re-plug.
2) Leave the breakers on the pedestal alone. High amperage breakers will age, more quickly when used as a "switch". My experience is 30-50% life reduction.
ChuckFeldt is offline   Reply With Quote
Old 10-13-2015, 12:12 PM   #12
2015 23' FB Flying Cloud
Redmond , Washington
Sounds like "life reduction" is the crux if the matter. But there is disagreement whether the emphasis is on the life of the circuit breaker or the life of the operator.
See: RV Electrical Safety: Part IV ‚€“ Hot Skin | No~Shock~Zone
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 10-13-2015, 12:22 PM   #13
Actually, see the 3rd bullet point under the section "Reruns" at this site for a more definitive answer:
http://www.noshockzone.org/rv-electr...80%93-outlets/
Old 10-13-2015, 02:51 PM   #14
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
I am the maintenance man at my rv park, have 175 sites all wired for 20,30 and 50 amp service, by far the biggest electrical problem I have here is from people who hookup or unhook their plugs without turning the breaker off. If everything in the rv is turned off there is no problem, however many people have lights and air conditioners turned on and it does cause some serious damage inside of the electrical boxes, outlets burned, wires melted and breakers fried. I shudder to think what is happening to the computers that many of the new motor homes have. My step father was an electrical engineer and he drilled it into my head at an early age - turn off before unplugging anything electrical.
PeterKV is offline   Reply With Quote
Throw rugs taught at Restoration Rally snakecharmer General Interior Topics 8 06-12-2012 12:59 PM
Sliding throw rugs noreen&sal General Interior Topics 8 05-29-2011 07:54 AM
Moving throw rugs!!! pappy19 Floor Finishes 11 04-10-2011 08:07 PM
throw this away Zeppelinium Off Topic Forum 20 11-01-2009 09:45 PM
The VAP Throw Down! robandzoe General Interior Topics 33 01-04-2008 11:50 AM
