Old 05-13-2012, 05:10 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Tired of bad 7 pin connections
Is there a better upgrade to the 7 pin flat terminal connectors. I'm tired of loose and bad connections. There should be a better way.
Old 05-13-2012, 05:22 PM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
How about the old style round pin? The flat pin was invented by the same SOB who came out with plastic headlight lenses, corn liquor in gasoline, etc. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 05-13-2012, 05:43 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Semi Trucks use the 7 pin round connectors. Truck stops carry a lot of parts.
Old 05-13-2012, 05:46 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Dielectric grease and zip-ties.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-13-2012, 05:57 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
My suggestion would be to switch over to the round 7-pin connector typically utilized in the trucking industry. I purposely ordered mine from a supply source that catered to over the road trucks to be certain that I was getting heavy duty units. With my most recent conversion, I went with Dell City and the product appears identical to what I purchased at the truck specialty outlet. The following components are what I purchased for my Overlander:Good luck with your investigation!
Kevin
P.S.: I have used this setup for four years now with excellent results. The tow vehicle end hasn't had to be disassembled and cleaned nor has the trailer end . . . that was an annual task with my old blade connectors . . . and the connectors often had to be replaced after the third year with the blade-type on my vehicles. The pin connectors are still trouble free at four years. I will probably disassemble them this year just to verify that all is well internally on both units, but I don' have any reason to think otherwise.
Kevin D. Allen
AIR #827
Old 05-13-2012, 06:35 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The problem I used to have was the fact that the connectors on the trailer cord would corrode with lack of use. I used to spay some electrical contact cleaner on them occasionally to keep the corrosion from forming on the copper contacts. Since I've moved to inside storage the corrosion problems have pretty much gone away.
Jack
Jack Canavera
STL Mo.
AIR #56
