Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-16-2012, 03:20 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Time sensitive - now power to outlets or microwave 23fb
I had my as into service recently as I had something catch inside one of the electrical outlets under the table. Just started her up and noticed I have no power to the outlets inside or out or the microwave. Just flipped all of the breakers and they seem fine.
Any other things I should check besides fuses?
It did take a bit longer for the electronics to fire up than normal when I pressed the use switch. Then all went on except those items.
Of course, we are supposed to be leaving on a trip tomorrow!
Advice?
bonginator is offline   Reply With Quote
Old 06-16-2012, 04:09 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I assume that you are connected to shore power (or a generator). If not, of course, none of your 110 outlets will have power.
In our 06 19' Safari SE if the GFCI gets tripped we lose power to half the outlets inside, the outlet for the frig, and the outside outlet. To reset it you have to turn the breaker off in the breaker box and flip it back on. That could be it.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 06-16-2012, 04:12 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
If it is all the items mentioned and they are on the same CB...that has to be the problem focal point. What "caught" inside one of the electrical outlets? You know...a ground fault plug could also cause the loss described. Se if any of the outlets has a reset button and push on it (all of them) and see if that fixes you up. Good luck.
Old 06-16-2012, 04:44 PM   #4
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
When you had the trailer in for service, they might have turned the Battery Disconnect Switch to "Store" position.
You might re-check to make sure that the switch in is in the "Use" position... when off shore power, you should see the red light on at this switch by your door if the switch is in the "Use" position.
SilverGate is offline   Reply With Quote
Old 06-16-2012, 05:23 PM   #5
2011 25' FB Flying Cloud
Anywhere & , Everywhere
But what could this possibly have to do with the AC outlets being dead?
Al - K4GLU is offline   Reply With Quote
Old 06-17-2012, 08:16 PM   #6
Boulder , Colorado
Thanks for all of the quick responses everyone. I was trying to pack up and this is our first trip this season. It was silly user error. I just plugged in my generator and voila I had power. Just needed shore power.
Blame it on my poor 50 plus memory...
Now in Saratoga, WY en route...
Old 06-17-2012, 11:08 PM   #7
SilverGate's Avatar
2007 23' Safari SE
You're welcome, bonginator.... thanks for posting what worked for you.
Looking forward to the story and pics of your first trip of the season!
Old 06-18-2012, 12:43 AM   #8
1976 Argosy 22
1975 31' Sovereign
Okotoks , Alberta
Bong!
Okotoks is offline   Reply With Quote
