Old 06-16-2016, 08:09 AM   #1
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 53
Tighten AC Power Breaker Screws
Am in Las Cruces, NM for 3 weeks, and it has been hot. Accordingly, the A/C runs much of the day, even with the thermostat set at 84.
One day the 20A A/C breaker tripped. As I went to reset it, I noticed the heat coming from breaker box enclosure. The left upper corner was VERY HOT to my touch.
Disconnected the trailer's power cable from shore power, took the breaker box cover off, and I checked all the screws. When I mean a screw was loose, I could noticeably feel a 1/4 turn or more while tightening it. I found these loose screws in the box:
- 30A main
- 20A A/C
- 20A circuit 4
- 20A GFCI
- 4 neutral screws
- 3 ground bar screws
Also reseated the breakers, and I noticed that the 30A main and 20A GFCI breakers didn't seem to have a firm, tight grip on the hot busbar. Am purchasing replacements today.
Also noticed that wires entering the panel are doubled up in the knockout strain relief. They look like regular Romex clamps to me. Looking at most packages, the UL listing is for one 12-2 Romex cable or two 14-2 Romex cables. The Airstream strain reliefs have: (1) 10-2 and 12-2; (2) two 12-2; and, (3) two 12-2.
As far as I can tell, all interior AC wiring is solid Romex, nothing stranded. Airstream is so stupid not to use stranded, marine grade wire.
I found several wire pieces and insulation pieces loose in the panel box. I seem to find wire clipping, wire insulation, and other trash every time I open an enclosure.
I can only wonder if this is another case of bad construction workmanship or just what happens after 13 years.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Over tighten lug nuts Pepsi Wheels, Hubs & Bearings 3 10-27-2012 09:47 AM
Towing a car with a dolly... tighten those straps and check them! Skater General Motorhome Topics 21 02-26-2011 11:02 AM
Does anyone know how I tighten this screw on the screen door holding clip? MikeDT Doors & Locks 9 04-18-2010 10:15 AM
How to tighten loose pocket door? tkoch General Interior Topics 1 09-04-2005 04:50 PM
Tighten old vs all new rivets lwebb Ribs, Skins & Rivets 28 02-11-2004 03:38 PM
