Old 11-12-2006, 09:55 PM   #15
millertime's Avatar
Valencia , California
Originally Posted by ROBERTSUNRUS
Hi, Jim Clark is right on track; More than likely a ground problem at your outlet. The little polarity checker is very simple to use / read and very inexpensive to purchase. A must for every trailer and house.
Yes I must get one ASAP!
Greg
millertime is offline   Reply With Quote
Old 11-12-2006, 09:58 PM   #16
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Originally Posted by millertime
So I was out doing my "pre-flight" today preparing for a trip in the morning and I went to check the tire pressure levels. I handled the left side first with out issues than I sat down curb side, my butt on the grass when I went to remove the vavle cap I felt as though I was getting an electrical current thru me but didn't take much notice to it. Than I put my tire pressure gauge on the valve and it and my hand touched the center metal cap on the alloy wheel and I definetley got zapped with an electrical current thru me!
So now I'm experimenting by physically touching the center cap and no doubt as I'm grounding my body to the grass there is current going thru me. If I stand up on the concrete and try it again, nothing....
This can't be normal is it?
For this you get a new nickname....Human fuse.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 11-12-2006, 10:05 PM   #17
millertime's Avatar
Thanks Milo!!
Old 11-12-2006, 11:56 PM   #18
_
Greg
every new a/s is delivered with a polarity checker, along with the silverware tray, soap dish, tp holder and so on...
it's a yellow 3 pronger, with a row of led lights.
has key stamped on it, for what the various light combinations indicate.
it should be in drawer somewhere and your sales person should have explained usage to you...
cheers
2air'
Old 11-15-2006, 07:26 AM   #19
JBK
JBK's Avatar
1986 34.5' Airstream 345
Grand Rapids , Up in the Nort' Woods of Minn.
Will SOMEONE please answer his repeated question "did I do any damage to the electrical system?" (Cuz I wanna know too...)
JB
86' 345 MH. Named "AirBus". The wife and I finally agree.
JBK is offline   Reply With Quote
Old 11-15-2006, 03:28 PM   #20
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
JB
simple answer no.
trailer electrical systems use a floating neutral. that means that the neutral (white wires) is not connected to ground as it is in your house. when the neutral becomes the hot wire nothing happens until you plug an appliance that has a grounded neutral, then you can energize the skin of the trailer.
the absolute worse thing that could happen is the cord of a neutral grounded appliance would be damaged. the basic wiring in the trailer would remain unharmed.
john
you call them ferrets, i call them weasels.
Old 11-23-2006, 09:56 AM   #21
millertime's Avatar
Originally Posted by john hd
simple answer no.
john
I feel much better now!
Old 11-23-2006, 10:11 AM   #22
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
glad to help!
john
Old 11-23-2006, 02:10 PM   #23
Excella CM's Avatar
1978 31' Excella 500
Venice , California
A good grounding in electricity is very beneficial. Take a look at one of the "household" type encyclopedias, it will explain the main ideas.
Also an old trick from the broadcasting industry: If you think some object might have errant electricity running around in just waiting for you to come along and serve as a path to ground, brush it with the BACK of your hand. That way, if there is some juice, your muscles will pull your arm back out of harm's way. Reaching out with an open hand in the normal manner can trap you if your fingers contract around whatever you touched. When ever I approach the old 'Silver Pullit' I brush the back of my hand against the trailer skin which reassures me that it is OK to grab the handle next to the door when I enter. It is a habit that also serves to remind me that electrical problems can occur, especially in campgrounds.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 02-04-2007, 01:31 AM   #24
Loren's Avatar
It seems to me that he got a good "grounding" in electricity.
Loren
2012 New Horizons Travel Trailer (formerly an Airstream owner)
2008 Dodge 2500 diesel with Equal-i-zer hitch.
Loren is offline   Reply With Quote
Old 02-04-2007, 11:35 AM   #25
Loren
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 02-04-2007, 04:57 PM   #26
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
This whole thread was shocking to say the least.
Good info to have. I happen to live near three very significant power lines and from time to time any metal we touch when we are out back near them will give you a shock. The lesson I learned is to not park my trailer or cars too near the power lines. I don't know why it happens. Some people are so sensitive to it that the hairs on their arms stand up, others don't feel a thing.
Barry
safari57 is offline   Reply With Quote
Old 02-05-2007, 07:18 AM   #27
"Some people are so sensitive to it that the hairs on their arms stand up, others don't feel a thing."
A lot of it depends on what footwear they have on. Highly electrically isolated footwear makes your conductive body accumulate a charge. This charge can be measured with a static voltage meter.
Live and LET live
FrenchBern is offline   Reply With Quote
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Normal Progression fhall9600 Member Introductions 2 10-28-2006 07:24 AM
water from A/C; normal or leak brunoffrance Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-15-2003 12:44 PM
Is it normal.... Safari Tim Our Community 9 06-30-2003 07:33 AM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 12:43 PM
