Old 06-14-2013, 12:38 PM   #1
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Things I think I know about my 12 volt system
Hello everyone,
I recent started a renovation of a 1976 22' Argosy and I am about to start rethinking the electrical system. I am a total novice at electrical systems aside from hooking up a few car stereo systems. I would like to shoot out a few things that I think I know and see if anyone can affirm or call me out on them. I also have a few questions.
1. All 12 volt power comes from the battery setup.
2. All 12 volt power runs through a fuse distribution panel.
3. Each separate 12 volt device in the trailer has it's own fuse.
4. Each fuse is rated to the wire and not to the 12 volt device.
5. The battery is recharged by the converter which is plugged into 120 volt power.
Feel free to call me out. So here are some of my questions:
1. How do I determine what gauge wire to use?
2. How do I determine what size fuse to protect that wire?
Some considerations.
I am planning on keeping all the current electronics installed but I want to add a few more items. I have already installed 2 - MaxxAir Fans. I plan to install a 12 volt LCD television. Finally I want to add a CD player and speakers. Are there any special considerations I need to take?
Thanks for any help on this matter. I have done a ton of searching and I either come up with nothing or something that feels too technical...
crabbey1 is offline   Reply With Quote
Old 06-14-2013, 01:31 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
12 volt is provided by the converter and the battery....primarily the converter when you are also using 110v which is "converted" to 12v. Fuse size is determined by the fixture using the power. If you use one size wire it simplifies things....use a 12 gauge and your covered. Ground (neutral) is either at the fixture or a white wire run to a ground point. If you standardize the wire colors it is best....black power....white neutral grounds. The tv and player need no special connections.
Old 06-14-2013, 01:53 PM   #3
crabbey1's Avatar
1976 Argosy 22
Images: 33
That is great info! Thanks!
How do I determine what size fuse to use per fixture? For instance, a 22" 12v LCD television?
Old 06-14-2013, 04:27 PM   #4
1988 32' Excella
Robbinsville , New Jersey
From converter when plugged into 120V otherwise yes.
Should, not definite if you're not the original owner.
No multiple things on some fuses.
In most cases, not all a few instances have the fuse size determined by the device often the radio (that is sometimes a second fuse that is inline for the radio).
Yes.
Here is a chart with wire sizing.
Wire Sizing Chart and Formula - RES Supply
See chart
Old 06-14-2013, 04:48 PM   #5
crabbey1's Avatar
1976 Argosy 22
Images: 33
Thanks Wazbro! Helpful info. So when you say multiple items are on one fuse, that could be all 12v lighting on one fuse?
Old 06-14-2013, 05:53 PM   #6
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
energy efficient lights
crabbey1, I used these LED's and they're really not too bad. 12V Warm White LED Puck Light. I wish they had a cool version also for the kitchen area.
surfpod is offline   Reply With Quote
Old 06-14-2013, 06:42 PM   #7
crabbey1's Avatar
1976 Argosy 22
Images: 33
Those are pretty cool but I don't think we will be doing any lighting changes. Maybe swapping bulbs. My GF wants to stay as close to the original as possible... Since we split the Argosy, she wins this battle.
Old 06-14-2013, 07:31 PM   #8
1988 32' Excella
I would hope not all lights in any trailer were on the same circuit, that would be poor planning, 1 fuse goes and total darkness.
I'm sure not all Airstreams are the same. In mine the radio, control center and front reading lights are on 1 circuit. In an Airstream I helped a friend with his fridge and the light over the sink were on the same circuit for 12V.
Old 06-19-2013, 03:47 PM   #9
crabbey1's Avatar
1976 Argosy 22
Images: 33
So his fridge was able to run on 12v?
Old 06-19-2013, 04:15 PM   #10
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Newer 2-way absorption fridges have a 12v control board, none that Airstream uses is a 3-way with a 12v cooling cycle.
David
Old 06-19-2013, 04:18 PM   #11
crabbey1's Avatar
1976 Argosy 22
Images: 33
Ok thanks! I have the original Dometic 2 way and it runs on 110v/LP...
Old 06-19-2013, 04:21 PM   #12
DKB_SATX's Avatar
1976 Argosy 28
I have had good luck with warm-white LED replacements for the bulbs in my Argosy's light fixtures. The ones I've bought so far aren't particularly cheap (I think I've averaged about $7/each) but I just took a risk on 2 lots of 10 lamps each on eBay that seem to be the same lamps that I've used already for about $3.50 each including shipping. My new 28' center-bath Argosy project has fixtures for 22 1156 bulbs, and would have 3 more if the original bathroom light were still there.
David
Old 06-19-2013, 06:17 PM   #13
1988 32' Excella
That's right just the control board.
Old 06-19-2013, 07:39 PM   #14
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
While I know you want to stay original, there are so many advantages to moving towards LED's. Not only are they much less power hungry they generate virtually zero heat. It's also possible to keep the same fixtures....
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
12 volt
