Old 03-10-2014, 06:48 AM   #1
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Hillpoint , Wisconsin
thermostat wire hook up 1973 Argosy
I forgot to document which wire went where when I removed the divider that the thermostat is attached to on my 1973 argosy. The colors coming from the thermostat do not match the color wires coming out to the wall. Does any one have a picture or that information?
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
and a partridge in a pear tree
Sprouty is offline   Reply With Quote
Old 03-10-2014, 08:15 AM   #2
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Picture of what I am working with
Here are the wires in question.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 03-10-2014, 08:21 AM   #3
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
I just remembered there is a light above the thermostat and I did see that the thermostat has 2 blue wires going to it in my furnace wiring diagram. I bet the two gray wires go to the light. Can any one confirm this?
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 03-10-2014, 08:45 AM   #4
1974 Argosy 20
Kooskia , Idaho
In general, the blue thermostat wires should remain blue to the furnace. That is, even Argosy, which did a lot of things strangely, didn't change wire colors in the wall. Now, from your post, it is not clear that you checked the color of the wires at the back of the thermostat. Did you?
You could put an ohm meter on the wires and then turn the thermostat up until it clicks, and see if the resistance on the wires decreases to near zero. That would confirm the pair for the thermostat.
Old 03-10-2014, 08:53 AM   #5
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
If you look at the picture there are blue wires coming out of the wall which I said I do have as correct from my diagram. Its the wires coming from the thermostat that are not matching up. I will look at the wires coming off the light and the thermostat like you suggest and that should tell me what's what thanks for the input.
Steve
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 03-10-2014, 09:04 AM   #6
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
They are hooked up and working! BTW the gray ones where for the thermostat and go to the blue wires. The black and green ones from the light go to the white and purple ones coming out of the wall.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
1973 argosy or 1989 as??? billy1davis Dollars & Cents 1 08-04-2011 07:37 PM
1973 Argosy JeanJacques Member Introductions 0 08-04-2011 09:57 AM
Purchasing advice 1973 argosy billy1davis Buyer Guidelines 7 08-02-2011 04:27 PM
HELP~ Looking at 1973 Argosy 20ft jahowie All Argosy Trailers 6 06-14-2011 07:33 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
