Old 04-29-2014, 05:50 AM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Thermostat changeover?
Has anyone changed the original equipment thermostat for the furnace to a more modern and convenient one? Every time that I push the on-off lever I fear that I'll cause breakage because it is so stiff. It sure would be nice to have a temperature readout. All help appreciated.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 04-29-2014, 08:09 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure what you are asking for will be available. The thermostat used in an RV is nothing more than an on/off switch. It does not have an anticipater. In order to get a readout you would have to supply a return line for the current driving the readout and not sure you would find a thermostat that has that function and runs at 12 volts.
You might try applying a small amount of dielectric grease to the friction point of the current switch that you find stiff.
2004 Excursion 4x4
Old 04-29-2014, 12:48 PM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
If you have the simple brown thermostat or something similar: Yes, we bought a cheap digital one and love it. It's really just like any other thermostat - note what terminals the wires come off on on the original one (they're marked with one or two letters), then put those wires to the same places on the new one. Generally you don't need a programmable 7-day thermostat or anything like that. It requires two AA batteries, but they last for years. The thermostat we got also does A/C, but our A/C isn't controlled through it, so we just ignore that side of it.
If yours is already nicer than our original one was, then I can't help you - it may be more complex for various reasons.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 04-29-2014, 02:18 PM   #4
1974 Argosy 20
Kooskia , Idaho
If you are looking for a heat only thermostat for the furnace, you can get any household one which has a battery to operate it. They have a relay inside which does the actual switching of the furnace on and off and will work well with the 12 volt furnace operation.
When you connect it up, wire the two furnace wires to the red and white terminals on the thermostat for proper heat operation. The Heat/cool/off switch can be set from heat to off when you want positive off when in storage.
If your thermostat operates the AC unit all bets are off and I have no advice as some of the AC units require a special thermostat and telephone wire and connector systems.
2 stage automatic/changeover lp regulator woes Roothawg LP Gas, Piping, Tanks & Regulators 7 03-17-2012 06:54 PM
Automatic Changeover Regulator 66Overlander LP Gas, Piping, Tanks & Regulators 50 10-10-2010 10:16 PM
Digital Thermostat jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-28-2009 03:20 PM
LP Tank Remote Changeover Indicator Wayward LP Gas, Piping, Tanks & Regulators 1 09-17-2007 07:38 PM
254 Automatic Changeover Regulator Striperv LP Gas, Piping, Tanks & Regulators 11 07-26-2005 09:16 AM
