Decided to high tech the step (over door) light on the old Silver Pullit, so...
Using a pre drilled circuit board cut to the shape of the lens, I mounted 19 super white 10mm l.e.d.s wired in series in groups of three, each group adjusted for voltage/current with a 100 ohm resistor. The odd man out was wired separately with a 470 ohm resistor. I potted the back side with polyurethane to protect the wiring and used a bulb socket so that it would plug into the existing recepticle. It draws about .4 amps and is bright as ----!
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
can't believe you retained the bronze age bulb socket as a connector...
__________________ MindsEyePhotoAirstreamDoctorPygmyKayaker "It must be laid down as a primary position and basis of our system, that every citizen who enjoys the protection of a free government owes not only a proportion of his property, but even his personal service to the defense of it." - Washington
Great project Bill. You could get a job at Radio Shack.
John
__________________ Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
I did something similar on my '73. Bought 4 "cool" blue LED's made to be mounted on the exterior of an automobile. I wired one in the over-the-door light like you did. Then a buddy made a mount that fits above the step. Wired all of that to the step light switch inside. No where as bright as yours, but I like the "Airstream" blue light glow in the dark.
Great looking work, Bill. Can you point us to any other LED work you've done?
Remember: If the enemy is in range, so are you.
Of course, retaining the "bronze age" socket allows one to revert to OEM style at the twist of a wrist. It also simplifies wiring. A truly thrifty person would use a burned out bulb
