Old 08-28-2004, 10:34 AM   #15
1 Rivet Short
krowsea's Avatar
Originally Posted by thenewkid64
Good catch John, I reread the thread and now see he is going to use an Optima. It may be time to get an intellipower, it has settings to charge different type of batteries so it won't kill a gel based or glass mat battery.
If I dive off the deep end, and decide to add the Intellipower to my already overflowing list of must haves, do I need to keep and adapt the Univolts fuse panel, or will my life be complete, the sun will be bright and the birds will sing if I merely replace one with the other?
John-Boy
Sarchasm (n): The gulf between the author of sarcastic wit and the person who doesn't get it.
1975 31' Sovereign
2004 Dodge Ram 2500 'Laramie', HEMI
krowsea is offline   Reply With Quote
Old 08-28-2004, 10:55 AM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
John-Boy
My understanding is that you will need the fuse panel from the Univolt, believe there are some pictures posted somewhere around here? I am considering the upgrade to Intellipower along with a marine style 12v circuit breaker panel...
Aaron
WBCCI #XXXX AIR #2495
Old 08-28-2004, 11:18 AM   #17
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
John-Boy
It is one of those it depends things
Depending on the year the fuse panel is part of the univolt. Yours could be in a remote location. If it is remote, then you are golden. If is part of the univolt, you will either need to dissect the univolt to reserve the panel, or get a replacement. If you get a replacement you could get one that uses the new blade style vs. the older glass fuse model. Most marine stores will sell a fuse block that can be mounted remote, just be sure to get one with enough slots.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-28-2004, 12:56 PM   #18
1 Rivet Short
krowsea's Avatar
Well, since the company I work for sells a multitude of hot rod, race car and performance parts, including electronics from this company http://www.painlessperformance.com/catalogframe.htm
I'll probably use one of their fuse panels if I need to switch. I'm hoping I don't have to switch anything out, but we'll see. Their complete fuse panels have circuits I don't need, along with some flashers and relays, but I can exclude those and relabel as needed.
John-Boy
1975 31' Sovereign
Old 08-28-2004, 01:06 PM   #19
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Cool, Parts at work!
There will only be 4 to 6 circuits to feed from the battery. The 4 fuse holders X 2 plus a couple of maxi fuse holders for the main feeds would do.
Brett G
Old 08-28-2004, 03:19 PM   #20
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Major Kewl! I want the flashers...be the FIRST in YOUR at your Airstream rally with the neon and really cool flashing light system. Gotta love it, if we want flashers we just plug one in the 7 way. Makes you easy to find and the life of the party
krowsea, any Airstream discounts?
Aaron
Old 08-28-2004, 04:33 PM   #21
North Central , USA
Pie!
Back in E.E. school I was learned about P=IE , it has something to do with cooking desert, me thinks. The prof said something about power, but all I do is get hungry?? Go figure !!
RivetED is offline   Reply With Quote
Old 08-30-2004, 07:17 PM   #22
1 Rivet Short
krowsea's Avatar
Actually, P=IE has two different versions, the beta mode, and of course, my personal favorite, P=IE ALA Mode.
John-Boy
1975 31' Sovereign
Old 08-30-2004, 07:22 PM   #23
1 Rivet Short
krowsea's Avatar
Aaron
I'm surprised, you sound like you've never seen an A/S with a flashing disco ball, Malibu curb lights and an assortment of body mounted colored lights that flash in time to the music. What... am I the only one?
John-Boy
Discounts, we don't need no stink'n discounts! (actually, we don't sell to the public, we sell to the jobbers, who sell to the public)
1975 31' Sovereign
Old 08-30-2004, 07:54 PM   #24
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
....Watts on my mind?
I'm going to be testing my Sovereign's elctrical system this weekend, in order to find out why some things work and others don't, as I mentioned before. I'll be checking the Univolt and fuses, and installing a brand spank'n new Optima battery.
snip.........
Thanks in advance, as the emergency room may not let me thank you after the fact, plus there will be lawyers and such hang'n 'round, it could get ugly.
John-Boy
keep doing that voodoo that you do so well...
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 09-03-2004, 02:42 PM   #25
1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
Optima
get me out of my confusion here. I thought Optima was gell cell until I went to their site and it said is was a lead acid with thin coiled plates instead of thick straight ones. I'm thinking of them so would like to find out.
Originally Posted by 74Argosy24MH
A Univolt is not a good charger for gel cell battery. They were designed when lead acid was the norm, charging requirements are completely different. It will work but the battery will suffer.
John
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 09-03-2004, 03:23 PM   #26
1 Rivet Short
krowsea's Avatar
Optimas are not gell cell. They call it an 'electrolite starved' battery, which simply means, there is no free electrolite in the battery. The lead plates are seperated by an electrolite soaked pad and there are no vents. That means the battery can be mounted on it's side, upside down whatever. Even if the battery was cracked or split, no fluid would leak out. I'm not sure if the lack of electrolite is the reason it's not supposed to be used with a Univolt.
John-Boy
1975 31' Sovereign
Connecting to Electricity ssolid Electrical - Systems, Generators, Batteries & Solar 22 02-12-2004 08:09 AM
Buying mattress pad? beware of Camping World false ad. femuse Our Community 5 03-19-2003 06:55 PM
Camping World - No A/C Pan? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-25-2002 08:55 AM
Goodyear tires available at Camping World 83Excella Tires 0 05-09-2002 08:29 AM
