Old 07-06-2009, 01:28 PM   #1
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
testing the control panel
things are getting interesting on my 72 Overlander.
I lost power to the control panel ( I have power to the gray wire that is the battery voltage, gray and black wires,) but there is no other power reading with my light.
We lost the overhead light fan, the water pump, and all the lights on the control panel.
What do you think and where can I get a way of testing the control panel'
Jpeterman
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 07-06-2009, 03:41 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Sounds like a fuse.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-06-2009, 06:23 PM   #3
jpeterman's Avatar
1972 27' Overlander
It does sound like a fuse, and that was the first thing I checked. All the fuses were good, I took all of them out and replaced them using dialectic grease.
Still no go, so I'[ll try to check the continuity of the wires tomorrow.
I just can't find a wiring diagram that tells what to check for 12v or ground.
Thanks for the reply though.
Jerry
"AIR 17559"
Jerry
Old 07-06-2009, 08:24 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I'm pretty sure the control panel has fuses, too. Did you check those?
Another thing. Since you say that the main fuse for the circuit is good, you may have a bad ground or short.
1958 Overlander
4CU 1st VP
Old 07-06-2009, 09:10 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Were you messing with the hitch wiring when it went out?
Circuit 5 - blue - feeds the panel and is also the charge line according to the diagram. Did you lose the reading lights also. Does the light AND the fan not work. The fan should be on circuit 5 - the light should be on circuit 4 - brown.
Old 07-07-2009, 10:14 AM   #6
jpeterman's Avatar
1972 27' Overlander
I did not see any fuses in the control panel box, we lost the fan and water pump, but all the lights work.
I haven't worked on the hitch wiring, but would like to know if that would cause a problem later.
Thanks again for everyone's input.
Jerry
"AIR 17559"
Jerry
control panel scottgaga General Repair Forum 2 06-18-2009 01:34 PM
Help- Control Panel went out all at once milesmason Electrical - Systems, Generators, Batteries & Solar 10 06-29-2006 08:56 PM
need help with control panel gord Electrical - Systems, Generators, Batteries & Solar 0 10-13-2004 06:46 PM
Control Panel RUSSELL Electrical - Systems, Generators, Batteries & Solar 4 08-04-2004 09:38 PM
GM a/c control panel rdm Mechanics Corner - Engines, Transmission & More... 5 11-11-2002 07:30 PM
