Old 06-29-2015, 10:13 AM   #1
rochar3's Avatar
2003 31' Classic
Valparaiso , Indiana
test panel
All systems working ok, but gray water reads empty all the time regardless of actual conditions.. Any suggestions for fix?
Bob-air # 657
I can win any argument on any subject. People know this and steer away from me at parties. Often as a sign of their respect, they don't even invite me.
rochar3 is offline   Reply With Quote
Old 06-29-2015, 10:50 AM   #2
richw46's Avatar
Lexington , Kentucky
If you have a Micropulse system, they are notorious for this. My fresh water no longer registers, gray water is always empty below 50 degrees and black water works no matter what. I think they have to cut into the belly pan to get to the sending units.
Some have converted to the Sea Level system (expensive). You can use the search feature to search for threads on Micropulse. There are a multitude.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-29-2015, 01:22 PM   #3
dznf0g's Avatar
Oswego , Illinois
I fiddled with the Micropulse for 5 years. Finally figured out a good system for reprogramming, but it inevitably goes out of calibration at least twice a year.
The only true fix is replace with a SeeLevel system. I did that swap this spring. I now can rely on the readings.
Did it myself, so it wasn't too expensive...$250ish IIRC.
-Rich-
Polishing a new panel to match an Alclad panel 66replica Cleaning, Stripping & Polishing 4 09-13-2014 12:29 PM
Test button on converter panel. flyslinger General Repair Forum 4 07-29-2012 02:01 PM
How To Test Holding Tanks hex Waste Systems, Tanks & Totes 1 11-19-2002 02:38 AM
Test hex Our Community 8 10-17-2002 04:20 PM
