Old 07-27-2003, 09:29 PM   #1
telephone connection?
Does anyone have any advice on how to install a telephone jack/connection for a 1974 Overlander? Is it possible? Thanks!
tonbis is offline   Reply With Quote
Old 07-27-2003, 09:43 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Anything can be done.
If you want to add one I would bring it in where the power cord and water enter the unit. Phone cord is small, so you should be able to run it to a convienent location without a lot of dissassembly.
On the newer models they use a 2 door exterior outlet cover and run both Phone and Cable into the unit. This is usally mounted below the lower rub rail midway between the rear bumper and the wheels. If you go this route you will need to add a circuit box, and may have to drill holes in the floor to feed wires. Not really a problem, just be sure to seal up the holes after you feed the wires thru.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-27-2003, 10:58 PM   #3
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Adding phone and cable jacks
I posted some pictures in another thread on how I added phone and cable tv jacks on my '71 Safari.
I ran the cable out the bottom of the trailer where there was already a vacant hole from when I redid the plumbing.
Maybe it will give you some ideas.
http://www.airforums.com/forum...round+internet
-Tim
theVAP - Airstream Podcast
Old 07-27-2003, 11:10 PM   #4
overlander76's Avatar
Send a message via ICQ to overlander76 Send a message via AIM to overlander76 Send a message via Yahoo to overlander76
My phone wire comes in under the fridge access door. It runs towards the front of the coach and the jack is next to the fold out table, in the same space.
overlander76 is offline   Reply With Quote
Old 07-28-2003, 01:35 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Question
Here is one I've been wondering....
The '03s came with a phone jack (inside). Where is the external connection?
Old 07-28-2003, 10:04 AM   #6
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
If it is like my International, it should be under a gray lift-up cover on the rear street side along with the cable TV connection.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 07-28-2003, 10:24 AM   #7
Thank you so much! We'll give it a shot.
Old 07-28-2003, 03:12 PM   #8
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
If it is like mine it is with the TV jack connection in the electric cord area.....by the way someone mentioned the push on TV cable connectors.....need one for mine....it is really hard to screw on the connection.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 07-28-2003, 06:16 PM   #9
Aluminut
2004 25' Safari
. , Illinois
Man do I feel like a air head!
I mistook that one in back for an electric outlet! Opened it up and sure enough, cable and phone!
Thanks all!
Old 07-28-2003, 08:47 PM   #10
Contributing Member
Pahaska's Avatar
You can say that again!
Trying to get my fingers in there to screw in the connector is a real hassle. Just went through that last Friday, then on Saturday morning I struggled to unscrew it again. Worse taking it off than putting it on.
John W. Irwin
WBCCI #9632
Old 07-28-2003, 08:50 PM   #11
Aluminut
2004 25' Safari
. , Illinois
Wink
Well now that I know where the darn thing is out there I can now easily see why so many folks have sat and/or cable TV!
Old 07-28-2003, 09:13 PM   #12
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Would this help??
90 Degree UHF for 4 bucks from radio shack. At the least it gets it pointed in the correct direction. Part number 278-0305.
Brett G
Old 07-29-2003, 07:01 AM   #13
Aluminut
2004 25' Safari
. , Illinois
Looking again at my external connection box, that might not allow the door to fully close when in transit. It's a fantastic idea though.
Eric
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 08:49 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
Water connection. Theo Fresh Water Systems 5 01-15-2004 04:09 PM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 10:06 PM
New City Water Connection j54mark Fresh Water Systems 5 07-01-2002 08:03 AM
