Old 11-19-2017, 01:46 PM   #1
2017 19' International
Tallahassee , Florida
Taking care of 7-way plug
What can I do to keep the 7-way plug in good health?
Should I give it a shot of WD-40 every now and then?
Should I use dielectric grease?
WhereStream is offline   Reply With Quote
Old 11-19-2017, 01:51 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I bought a rubber cover that fits over the end of the plug to keep it clean. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Cats and ultraleather Airstream upholstery don't mix!
Old 11-19-2017, 01:53 PM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Google is your friend https://www.etrailer.com/question-61101.html
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 11-19-2017, 02:45 PM   #4
Mount Dora , Florida
I bought that same cover.
If you hang the umbilical over the back of your tongue jack the cover will be on the bottom, and rain will fill the cover with water. The water will stay in the cover and cause problems. In my case the right turn signal light comes on.
Open the cover, shake off the water, and the light goes out.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 11-19-2017, 02:55 PM   #5
Then don't hang the umbilical over the tongue jack! (Like that old joke, "Doc, it hurts when I do that." "Then don't do that!")
Just use a big Velcro cable tie to fasten the umbilical to the tongue jack, with the plug (and cover) facing up. Then no rain enters the plug with the cover on. Problem solved.
Old 11-19-2017, 02:59 PM   #6
I no longer “do that”. At least not with the cover on.
2017 FC 27FB
Old 11-19-2017, 04:13 PM   #7
NukeSubSailr's Avatar
2010 20' Flying Cloud
Surry , Virginia
I dangle a bungee cord down inside the propane cover, hook the umbilical cord plug and pull it up into the cover protection and hook the other end of the bungee to hold the cord inside the cover.
NukeSubSailr is offline   Reply With Quote
Old 11-19-2017, 05:47 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
It lives inside with the LP tanks covered with dielectric grease, open end down.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-19-2017, 06:32 PM   #9
2016 30' International
redondo beach , California
I use a 7-way plug extension chord.
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 11-19-2017, 06:34 PM   #10
Kensington , Maryland
Keep a coat of di-electric grease on the metal bits and there is not much else to do!
2017 25' FC FB "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 11-19-2017, 08:27 PM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
I rinse it out with brake cleaner about once a year and put dielectric grease on it afterwards. I just drape it over the frame...no cover.
CRH is offline   Reply With Quote
Old 11-19-2017, 09:05 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I took care of mine by replacing it with something better.
After much procrastination, I finally got around to replacing the RV style connector with a 7 pin round connector that is used in heavy truck service. They are simply a lot better.....
J. Morgan is online now   Reply With Quote
Old 11-20-2017, 07:34 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
i clean it with crc electronic cleaner spray before each use. works great and easily found at hd or lowes
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-20-2017, 07:56 AM   #14
Mollysdad's Avatar
This.
Products like WD-40 attract dirt. Bagging or sealing the plug encourage condensation when the temp changes.
I hang mine over where the tongue jack and propane cover meet. With the plug facing down and it's molded, no stuff gets in.
I do like the "Hood" that's available with Husky jacks.
In transit, I pass the cable through the "safety pin" that prevents the coupler from opening. That way the cable is centered, so left and right turns don't tug on it.
Mollysdad is online now   Reply With Quote
Taking care of New Clear Coat adonh Clearcoat, Exterior Paint & Trim 6 06-26-2012 10:58 AM
Inexpensive way to protect your 7-way plug SmokelessJoe Lights - Interior & Exterior 6 03-05-2011 02:08 PM
Taking care of Toby Alumanutz The Pet Forum 3 08-14-2008 06:54 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
