Old 09-09-2004, 08:20 PM   #15
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Brad,
I live in the Pacific NW also and like to be seen on the dark and rainey nights. I have seen some options out there. Let me know if you want my two cents.
Lee
silverleeper is offline   Reply With Quote
Old 09-10-2004, 09:30 AM   #16
walter1's Avatar
1964 22' Safari
Foresthill , California
I would like want your 3 cents worth and any info on this. I have a 64 Safari and would also like to retrofit leds and still use stock Bargman 99 lens
walter1 is offline   Reply With Quote
Old 09-10-2004, 10:59 AM   #17
1975 24' Argosy 24
Burlington , Ontario
tail lamps
Originally Posted by Trailer Girl
I am having problems figuring out the correct bulb to purchase for the tailights on a 1964 Overlander. The bulb with the single contact worked out fine, but I am having no luck getting the bulbs with the 2 contacts to fit down far enough... so I must be using the wrong bulb. Abyone know the corect bulb number?
Install # 1157 dual contact lamps. They are standard auto 12VDC lamps available at any auto suppy store. Also you will note that the bayonet on the case are off set. there is only one way to install them look at the lamp and then the socket . One pin or bayonet is off set.
Rae
raebaker06 is offline   Reply With Quote
Old 09-10-2004, 04:19 PM   #18
1967 22' Safari
1960 Caravel
Images: 8
Hi Walter1,
I have found two options on Ebay. Search for "1157 super white red right angle 30 LED bulb" and "1157 red 90 degree aka flat LED light bulb". If you have any problems I can send you the links. Hope this helps.
Lee
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
Bulbs - Tail and Clearance Zed2 Lights - Interior & Exterior 3 07-13-2005 11:53 AM
Florescent light bulbs AccessMaster Airstream Motorhome Forums 5 11-30-2003 05:35 PM
taillight bulbs davidz71 Lights - Interior & Exterior 4 02-14-2003 08:59 AM
Taillight gaskets? davidz71 Lights - Interior & Exterior 0 09-10-2002 05:26 PM
