Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Prev Previous Post   Next Post Next
Old 07-17-2003, 09:32 PM   #1
Profile:
Question Tailight Wiring '62 Overlander
I have a 1962 Overlander which I picked up a month or so ago. Upon inspection of the exterior lights - brake, turn, running etc. I have found a problem I can't solve. All of the exterior lighting works perfectly, except for when I turn on the right turn signal. When the right signal is activated, the left signal blinks as well - like hazard lights are on. No other lights are affected by this or any other variable of light operation. I have checked the truck plug end and it is OK. I have checked the plug end on the trailer and all is wired correctly with the truck end. I have checked the wiring at the access panel in front and it checks out OK - that's as far as I could get without tearing into panels. Any ideas? Anyone know where the wiring runs from the access panel?
Thanks in advance!
Deppdog
Deppdog is offline   Reply With Quote
62 Overlander pic 62 Overlander 1958 - 1963 Overlander 20 08-30-2007 10:18 PM
Entry Door Wanted '62 Overlander Deppdog Parts Archive 0 09-10-2003 10:12 PM
Suburban tow package wiring question uwe On The Road... 9 08-29-2003 03:08 PM
Tail Light on '62 Overlander Deppdog Electrical - Systems, Generators, Batteries & Solar 1 08-16-2003 09:21 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 03:16 PM
