Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-28-2003, 08:01 PM   #1
sshadow
Profile:
Question Tail Light Wiring
We just bought a 1970 Safari and I'm trying to get all the lights working properly. I have both left and right turn signals but only the right side tail light. Also, only the right side lights with the brake applied.
Is there a wire that runs from the right side to the left for tail light and brake control? How do I get at the wiring?
Any help will be greatly appreciated.
~sshadow
sshadow is offline   Reply With Quote
Old 10-28-2003, 08:06 PM   #2
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
I had simular problems first time I plugged ours in. Turned out to be some dirt and corrosion in the plug on the trailer side. little scraping the corrosion loose with a flat blade screw driver and it cured the problem.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-28-2003, 08:23 PM   #3
Creampuff
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
Look for an inspection plate cover on the bellypan curbside near the front. If it's the same as my '67 the wiring is junctioned from the tongue 7 way connector to the individual wiring which runs down the inside of the curbside framerail. The taillight wire also powers the running lights .
If 'Toaster's trick doesn't work , post again and I may be able to walk you through the rear end ,assuming the wiring is the same as mine.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 10-28-2003, 09:27 PM   #4
Stinky
Stinky's Avatar
Profile:
Question rear tail lights
I posted earlyer but to no avail. I need to replace the rear lights on my 69 overlander but I can't figure out how to get to them. The sockets and housings are rusted and no longer work.
Stinky is offline   Reply With Quote
Old 10-31-2003, 11:17 AM   #5
daniel
Profile:
rusted tail lights
I also had to replace the tail/stop/backup lights on my 69 caravel. Had to remove entire light by drilling out the rivits. It seems that they had be replaced by po. Purchased new from inland rv. Had to drill and pop riv back. Took some time but works fine.
Dan
sprusegoose
daniel is offline   Reply With Quote
Tail Light on '62 Overlander Deppdog Electrical - Systems, Generators, Batteries & Solar 1 08-16-2003 09:21 AM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 01:38 PM
how to replace 70's tail light unit qqq Airstream Motorhome Forums 1 02-02-2003 01:04 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 12:03 PM
test
