Old 06-07-2005, 09:34 PM   #1
Angry Tail light red, green, yellow wires?
I have a 1964 Globetrotter with the old wedding cake tail lights (broken and cracked.) I'm replacing them with InlandRV replacement lights. The three wire colors eminating from my trailer tail lights are: red, green, and yellow. The wires on the new replacement tail lights are: red, black, and white.
Does anyone know which trailer wires go to which replacement light wires?
Perplexed!
PKelley is offline   Reply With Quote
Old 06-07-2005, 10:22 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
It's
Perplexed!
I've yet had to order replacements or use one of the repro on my 64GT...
If you have a voltmeter, you could try taking a reading of voltage while someone hits the brakes, etc.
Or simply:
Why not try it in the order you mention??
After all, what's the worse you could do? (If it sparks on you be QUICK..lol)
Report back with your results.
BTW, How do they look compared to the originals>??
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 06-08-2005, 07:28 AM   #3
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Sounds like the old Bargeman 99 lights. I wonder if I could ask you one thing--why replace the whole light assembly if the only problem appears to be cracked lenses? Unless the original wiring doesn't work, it's much easier (not to mention cheaper) just to replace the lens and, if necessary, the light bulb. I did that on mine--took about 5 minutes, no wires. If that works, return the unnecessary parts for refund--and you will have saved a bit of cash.
Just don't over cam the screws--the lense will break (I found this out the hard way--repairing it took a bit more time <g>).
Mary
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 12:52 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Bargman #99 wedding cake Tail light needed CindyH Lights - Interior & Exterior 8 10-16-2002 08:52 AM
