Tail Light on '62 Overlander
As I mentioned in an earlier post, I am having trouble with the right turn signal. I have narrowed the problem down to one bad wire from the access port, back to the light itself. I ran an external wire to test, and it works fine. My question is:
Does anyone have a good method of running a wire internally to the tail light? The belly pan already has a few access ports in it, but when you get to the back section, there is some structural wood that blocks the path up to the light. I also think there is some wood higher up, just below the light that would be a problem. Any tips would be greatly appreciated.
Thanks in advance!
Deppdog
