Old 10-25-2015, 08:41 PM   #1
Mossyrock's Avatar
1992 29' Excella
Mossyrock , Washington
Surprise, I've got a solar panel...Help!
92 Excella 1000 29. I was up on top resealing a vent and happened to notice that on top of the AC box is a solar panel. I've only owned the unit for a year and just had not noticed it before.
I would appreciate any info...how do I find out if this was factory installed as an option in 92? How do I know if it is working or not? Should I look somewhere obvious for SN or make/model number?
Tim
Mossyrock is offline   Reply With Quote
Old 10-30-2015, 09:46 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I doubt that it was a factory install. You need to trace the wires to see if it is hooked up. As well, there should be a solar controller somewhere. My guess is that it would be no more than a 50-watt panel; but that's enough to top up your battery.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 10-31-2015, 12:04 PM   #3
Mossyrock's Avatar
1992 29' Excella
I appreciate this support. Have not seen anything that looks like a solar controller but will check the wiring to the batteries and see if it looks like they are supported by the solar panel.
Tim L
Old 10-31-2015, 01:36 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
My 91 classic has the solar pre wire. I find the labelled 8 awg wire up front under the sofa, but never found the other end despite removing g the fridge, lights, cabinets....
In those days the single solar wire was red per my manual.
It was grounded at the fridge connection . Very poorly designed system. Factory controller was made by American Ziettler.
Old 11-01-2015, 01:16 PM   #5
Mossyrock's Avatar
1992 29' Excella
Atomic - thanks - can I ask a couple of questions since you have direct experience? I am confused by "never found the other end"...wasn't the "other end" the solar panel end?? Does "up front under the sofa" mean that you took up the floor panels and found the red wire underneath? Did the red wire lead directly to the battery or batteries? I've got the owner's manual and don't find a word about the solar panel.
Regards, Tim L
Old 11-01-2015, 01:27 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Mine was just pre wired, no panels or controller were ever installed! I installed my own proper wiring, PV panels, controller, breakers, battery bank, and other monitors. Under the sofa area, the solo red wire emerged from the skin of the front wall, coiled up and wire tied with a label saying "solar panel".
The other end of the wire is a mystery, I simply cannot find where it terminates. I can follow it the length of the trailer hallway, past the fridge, then it crosses over the roof to the curbside of the hallway seemingly over the bathroom.
I eventually ran 1/0 fine strand Litz cable through the frame to my controllers on the front wall.
Old 11-04-2015, 11:41 AM   #7
Mossyrock's Avatar
1992 29' Excella
Atomic. Good stuff. For mine there is no evidence of this wire under the sofa nor a controller anywhere...only the panel on the roof and some black covered wiring from it that enters the roof nearby. But I do believe you are correct that this was factory install although my owner's manual doesn't address the subject.
Winterizing the unit today here in western Washington. Going to pull the batteries this year so I'll look carefully for extraneous wires when I do that. Thanks for the kind support. Rim L
Old 11-04-2015, 11:52 AM   #8
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
When we purchased our Airstream the original owner had wired a 5-watt harbor freight panel straight to the batteries and mounted it on top of the Propane lid. He did not use a charge controller or anything.
I think it was his idea of a battery tender. You're previous owner might of been related.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-04-2015, 12:09 PM   #9
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
The early 90s were a very long time ago. It was not too common to have a solar anything!
Slow Cookers..... please help me surprise her. Gator113 Stella's Kitchen 23 08-21-2010 08:51 AM
Solar Panel Help Needed DaCosta Generators & Solar Power 14 06-02-2010 08:13 AM
Solar Panel Trouble Shooting Help upstateart Winter Living 8 01-31-2010 07:13 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
