Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-17-2015, 01:39 PM   #1
2011 28' Flying Cloud
Tallahassee , Florida
Surging hum near fridge in stored FC28
Our 2011 FC 28 has been stored for about a month, plugged into 15 amp. Just checked inside and there is a fan cycling on and off. It is loud and sounds like it is in the fridge. It churns. The fridge is turned off, doors open. Unplugging from shore power turns off the hum, but the batteries seem to be drained. When plugging the power back on, the fan noise does not come on again until I hit the "store" switch. Then it will not go off unless it is unplugged from shore power. The temp inside the trailer is 82, outside temp 78, it is a sunny day and the sun is currently hitting the side of the trailer the fridge is on. Is this because of the heat, is it necessary? Has it somehow drained the batteries? Is it something to worry about?
kathrynlord is offline   Reply With Quote
Old 07-17-2015, 02:12 PM   #2
"Cloudsplitter"
Thumbs up Welcome Aboard....
Sounds like the converter/charger cooling fan is running full time.
The batteries have been overcharged, boiled dry.
IIWY...I'd get a new 3 or 4 stage converter, and new batteries.
The new converter will prevent the batteries from overcharging when plugged in for extended periods.
Randy @ Best Converter is a good place to start your research, very helpful and won't steer you rong.
At the very least you'll probably need new deep cycle batteries and then test the converter for output.
ROBERT CROSS is online now   Reply With Quote
Old 07-18-2015, 09:05 AM   #3
Thanks, Bob, for the quick advice. Sounded right, but my husband thinks he has figured it out, and I'll have him write it out here:
Turns out that there is a fan underneath the refrigerator that helps to cool the compartment. The thermostat must have gone bad; the motor even ran during the night when the temperature in the compartment was very cool. Looks like other people have had this problem, and in the AS manual they suggest turning it off temporarily if it is cool and the fan noise is bothersome. So...thanks for your help, luckily it is not a serious problem.
Yamaha 2400 motor surging Boondocker Generators & Solar Power 5 04-30-2011 10:45 AM
Generator Surging jking Classic Motorhomes 13 04-11-2011 08:24 PM
Why does my electrical seem like its surging dmcinfo Lights - Interior & Exterior 1 07-08-2010 10:48 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Surging Generator 02safari25 Mechanics Corner - Engines, Transmission & More... 7 11-14-2006 06:18 PM
