Old 12-14-2014, 05:25 AM   #29
Tincampers's Avatar
Sneedville , Tennessee
I went ahead and got this one:
Progressive Industries PT30C 30 Amp Portable Electrical Management System
Peace of mind is priceless.
Tincampers is offline   Reply With Quote
Old 12-14-2014, 05:38 AM   #30
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
I use their EMS-50PTC and like all the data. Yes, peace of mind.....
Ms. Tommie Lauer
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 12-14-2014, 06:11 AM   #31
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Thanks for the info mrprez, Msmoto, and Bob. Piece of mind is good. Sold. Jim
Jim Flower is offline   Reply With Quote
Old 12-14-2014, 06:51 AM   #32
mefly2's Avatar
2015 25' FB Eddie Bauer
I should also add that in addition to the power cord surge protector, we leave the (supplied with recent model AS) small power monitor (with three visual indicators) plugged into the bathroom electrical receptacle as a night light ... it just provides another eye to what is going on with the electrical system.
Old 12-14-2014, 10:28 AM   #33
Storm Master
Ampman's Avatar
2005 25' Classic
Every rig has a different location for the main panel and hooking up a hard wired unit may be easy or a pain. The portable unit makes more sense and that's what I will go to when my hard wire unit fries. Plus you can drag it with you if you trade your rig.
Ampman is offline   Reply With Quote
Old 12-14-2014, 11:51 AM   #34
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by Silvery Moon View Post
So we use the aforementioned surge guard, and when we're actually drawing on a 30 amp feed, we also use this voltage regulator: http://www.amazon.com/Technology-Res...dp/B00A0RANJ6/
They also make a 50-amp version. It's quite a brick, but we like the extra protection - it could save our heat pump from low-voltage damage. This item boosts voltage by as much as 10% (e.g. from 95 volts) before it gives up, turns off the power to your rig and waits for better conditions before resuming the power feed.
The Progressive solution may be more cost-effective since it protects both against surges and low voltage, but we didn't know about it then.
Thanks for your input. I am looking at getting the Technology Research unit for New Lucy. I have never had a surge protector before. I am reading that this unit is both a surge protector and a voltage regulator. Is this correct?
Brian
SuEllyn & Brian McCabe
Old 12-14-2014, 12:30 PM   #35
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
PT 30C has a decent price today at Camping World on line. $218 plus shipping $9. Ordered. Two weeks shipping which is ok for me but a tad slow by today's standards. Jim
Old 12-14-2014, 12:35 PM   #36
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
Buy one.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 12-14-2014, 12:36 PM   #37
Tincampers's Avatar
$215 on Amazon with free Prime shipping or free Standard shipping (you'd have it next week..
Old 12-14-2014, 01:37 PM   #38
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Brian
It doesn't regulate, only monitors the voltage, shutting it off if it is too low or high. Nifty unit, goes through a variety of power checks when first plugged in before it allows power to pass to your Airstream. I feel very good about the power source with this plugged in to protect our electrical system.
Doug and Cheryl
Old 12-14-2014, 02:01 PM   #39
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Originally Posted by silverbp View Post
Buy one.
Yup. Got one. And mrprez, I never go shopping after I have been shopping. Another way to avoid being disappointed. But thank you for the heads up anyway. Jim
Old 12-14-2014, 02:10 PM   #40
Tincampers's Avatar
Well, if not for you then for those who follow.
Old 12-14-2014, 03:28 PM   #41
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Cool Regulators and suppressors
Hi there! To be clear, we own both a surge guard and a voltage regulator. The surge guard is *not* a voltage regulator. While a TRC surge suppressor / Progressive EMS is sufficient to prevent disaster, you may be happiest having both a regulator and a suppressor.
Here's the configuration if you use a regulator and a suppressor. If you have a 50 amp system, replace my 30's with 50's.
Post ==> 30-amp extension cord ==> Voltage regulator ==> TRC Surge Guard *or* Progressive EMS ==> Furion 30-amp cord ==>Trailer
This way, the voltage regulator minimizes the potential variations in voltage coming off the post, boosting voltage by as much as 10% (e.g. guaranteeing clean service on the output side even with input voltages as low as 95 volts). However, the regulator does *not* protect against anything else. So, you still need a TRC surge guard or Progressive EMS in the circuit after a regulator. Either of those will protect against surges, open neutrals, etc. Lastly, you plug the now regulated and surge-guarded output into your trailer.
As a matter of convenience we put the voltage regulator and surge guard under the trailer where they are harder to see and perhaps less likely to be "borrowed". We never just hang the surge guard from the post. It looks way too interesting. (Obfuscation is not the same as security, but at our trailer the average looky-loo sees an extension cord going under the trailer and a Furion cord coming out from between the wheels...probably nothing interesting going on under there, not even worth bending down to take a peek.)
We didn't wire this stuff into the trailer because the purpose of these devices is to sacrifice themselves if necessary. If (when?) they get smoked by an evil power incident, we can replace them without messing with any trailer innards. If the devices are stolen and the baddies stop with carrying off 30 pounds of electrical gizmos they don't really understand, I guess we'll be grateful the incident wasn't worse.
Brian
Old 12-14-2014, 03:34 PM   #42
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
The EMS unit works very well (installed the hard-wired model). What I particularly like about it is that IF there is an issue in the campground, you'll get a code on the display BEFORE it connects your trailer to the power. I had one campground with a polarity issue, and another with inadequate voltage to run my A/C. You always have the option to override it, but I sure wouldn't. It's available in both a 30amp and 50amp model and (surprisingly) is made in the USA!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Surge Guard protectors with locking hasp jtbarbee Electrical - Systems, Generators, Batteries & Solar 5 05-03-2014 03:29 PM
SurgeGuard Surge Protectors TexasJudge General Repair Forum 4 03-18-2014 07:07 AM
Updates on surge protectors? Scott J-24 Batteries, Univolts, Converters & Inverters 56 08-01-2013 10:29 AM
Surge Protectors and Such.... luckydc Electrical - Systems, Generators, Batteries & Solar 26 08-17-2010 12:08 AM
RV Surge Protectors Tin Hut Electrical - Systems, Generators, Batteries & Solar 4 06-09-2004 05:37 PM
